If I understood his last message correctly it works OK printing values for 10 seconds, and then it fails. So it does find the PV.
Sent from my iPhone
Hi Le Daniel,
I would guess that the PV is actually not being found on the network. Is EPICS_CA_ADDR_LIST set so that the IOC or CA server providing that PV can be found?
On Mon, Sep 19, 2022 at 7:18 AM LE-DANIEL Erwann via Tech-talk < [email protected]> wrote:
Hello,
I’m using a raspberry to get epics variable value from that code :
import epics
import time
while True:
p=epics.PV(‘TL_AN_Input’)
val = p.get()
print (val)
time.sleep(0.1)
This code runs about 10 seconds and after it returns the error message :
/home/pi/.local/lib/python3.9/site-packages/epics/ca.py:1528: UserWarning: ca.get(‘TL_AN_Input…’) timed out after 1.00 seconds.
Warnings.warn(msg % (name(chid), timeout))
What does it mean ?
Is it because I need to clean the PV_cache ?
è if it is the case how can I do that ?
Thank you very much.
Cordialement,
LE DANIEL Erwann.
CONFIDENTIALITY : This e-mail and any attachments are confidential and may be privileged. If you are not a named recipient, please notify the sender immediately and do not disclose the contents to another person, use
it for any purpose or store or copy the information in any medium.
- RE: warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
- warnings.warn from raspberry pyepics LE-DANIEL Erwann via Tech-talk
- Re: warnings.warn from raspberry pyepics Matt Newville via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
