1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Change PVA structure dynamically during IOC operation
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Alnajjar, Dawood" <[email protected]>
Date: Wed, 28 Sep 2022 18:25:31 +0000
> I need to change a PVA structure dynamically during IOC operation. Looking at pvxs::ioc::server, I do not see an update function that allows that. Does anyone know if this is possible?
I don't think that's possible.
If you check the protocol documentation, https://github.com/epics-base/pvAccessCPP/wiki/protocol, you'll find that the overall structure information is exchanged once when a client connects. From then on, only a compact bitmap that indicates what changed is sent, plus the modified values.
To change the structure, the protocol would have to send the complete new structure.
Arrays can change the number of elements, but the overall structure stays the same because the protocol was optimized for this.
Re: Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Re: Change PVA structure dynamically during IOC operation Andrew Johnson via Tech-talk
Prev: Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Next: Re: Change PVA structure dynamically during IOC operation Alnajjar, Dawood via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
