Hi Heinz,
Yes, on the EVR and EVM the VME interface is implemented in a Kintex 7
FPGA, but the code is not related to the board from Struck.
In the interrupt handler you have to make sure to read back the register
clearing the interrupt flag after clearing the flag with a write. This
is to flush the write pipeline of the VME bridge of the CPU module
before exiting the interrupt handler. Otherwise it may happen that the
interrupt line is still active after leaving the interrupt handler and
another interrupt is requested immediately after exiting the handler but
there is no card acknowledging the already handled request.
Anyway, using a VME bus analyzer is the way to go. I'm wondering how the
bus arbitration can affect this.
Jukka
On 10/5/22 2:02 PM, Heinz Junkes via Tech-talk wrote:
I'm getting a little puzzled now.
I had similar problems with the interrupt vector on the VMEBus with the VMEbus board from Struck (SIS3316).
I could prove with a VMEbus bus analyzer (VMEtro) that Struck does not leave the vector on the bus long enough.
This was then fixed by Struck by adapting their VME-FPGA programming.
If I understood correctly, they use a Xilinx Spartan 6 FPGA for the VMEbus control.
With faulty register reading I had the same assumption that the timing of the FPGA is not kept
properly (this could have something to do with the clock frequency of the FPGA).
But here we didn't really come to a solution and to be able to put the system into use I found by chance
the the 2 CPU solution and use it since then.
Do the EVM and EVR boards also use FPGA's for the VMEbus?
Heinz
On 5. Oct 2022, at 04:38, Hong, Ran <[email protected]> wrote:
Dear Heinz,
I tried the 2-CPU scheme and it seems working. I have mvme3100 as the arbiter and mvme2500 as the CPU for the IOC. I will investigate a few other places of the code and see if this problem goes away. Particularly, I will check the ISR function. I had interrupt problems before. If I had more than 1 EVR in the crate, it had interrupt errors. I solved this problem by adding a read-back in the ISR function, but I had no idea why that could work.
Ran Hong
Sent: Tuesday, October 4, 2022 6:34 AM
To: Hong, Ran <[email protected]>
Cc: [email protected] <[email protected]>
Subject: Re: Read and Write errors with VME-EVR-300
Hello Ran Hong,
I have similar problems in a constellation with MVME6100 and STRUCK SIS3316.
I could solve the problem ( not elegant ) by using another (old) CPU as VME arbiter in slot 1
and disabling the arbiter on the MVME6100 and plugging the CPU into slot 2.
Heinz
On 4. Oct 2022, at 02:29, Hong, Ran via Tech-talk <[email protected]> wrote:
Hello All,
I am testing a VME IOC with 1 VME-EVM-300 and 6 VME-EVR-300 boards. The CPU board is mvme-3100, and the driver is derived from mrfioc2:
https://github.com/epics-modules/mrfioc2
I experienced many errors like missing time stamp, incorrect GTX waveform, and so on. They all stem from issues when reading from or writing to VME registries using READ32 or WRITE32 in the driver. For example, in evrMrmApp/src/drvem.cpp line 803 to 806 for latching the timestamp,
epicsUInt32
ctrl=
READ32
(base,
Control);
Latch timestamp
WRITE32
(base,
Control, ctrl|Control_tsltch);
It reads the control registry, modify the bit for timestamp latch, and write it back to the control registry. Occasionally, I saw the READ32 returns 0xffffffff, which is an invalid value for the control registry, and the subsequent WRITE32 results in a mess in the EVR.
Has anyone experienced similar issues? Any suggestions to prevent or mitigate the VME I/O errors?
Thanks!
Ran Hong
- Re: Read and Write errors with VME-EVR-300 Michael Davidsaver via Tech-talk
- Read and Write errors with VME-EVR-300 Hong, Ran via Tech-talk
- Re: Read and Write errors with VME-EVR-300 Heinz Junkes via Tech-talk
- Re: Read and Write errors with VME-EVR-300 Hong, Ran via Tech-talk
PVXS and Phoebus Florian Feldbauer via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
