1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Phoebus zoom etc toolbar
From: Steve Kinder - STFC UKRI via Tech-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, tech-talk <[email protected]>
Date: Mon, 10 Oct 2022 19:14:15 +0000
Can you suggest any way to disable the display toolbar for all displays? Or perhaps for individual bob file displays? The most likely route seems through a memento file or layout. But I don't want individual displays to always be there at startup. Whenever they start I'd prefer to disable the display toolbar.
Steve
Sent: 10 October 2022 16:53
To: Kinder, Steve (STFC,DL,TECH) <[email protected]>; tech-talk <[email protected]>
> Thanks for the reply. I'm using Phoebus 4.7.1. I've tried that and it seems to hide the toolbar above that, with the home button, top resources etc, but not the one with zoom etc.
There are two toolbars.
The checkbox in the "Window" menu is for the global toolbar with "Home", top resources, saved layouts, ...
The context menu of the display controls the toolbar within each display with zoom, back/forward, ...
I'm sorry that they're both called toolbar.
-Kay
Sent: 10 October 2022 15:39
To: tech-talk <[email protected]>; Kinder, Steve (STFC,DL,TECH) <[email protected]>
> I'm not sure toolbar is the right name. When I execute my displays in cs-studio I always seem to get an extra 'toolbar' with a zoom levels menu and a couple of controls to select displays. Is there an easy way to stop this being added that I haven't found yet?
Not sure about the right name as well but that's what it's indeed called.
Right-click inside the display and select "Hide Toolbar" to hide that toolbar within each display, the one with the zoom and back/forward buttons.
The setting then stays that way for newly opened displays until you decide to "Show Toolbar" again in any of the displays.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Phoebus zoom etc toolbar Kasemir, Kay via Tech-talk
Phoebus zoom etc toolbar Steve Kinder - STFC UKRI via Tech-talk
Re: Phoebus zoom etc toolbar Steve Kinder - STFC UKRI via Tech-talk
Prev: Re: mbbi excessive archiving William F Badgett Jr via Tech-talk
Next: Re: Phoebus zoom etc toolbar Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Phoebus zoom etc toolbar Kasemir, Kay via Tech-talk
