1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: add motor module in synapps
To: tech-talk <[email protected]>
Date: Mon, 17 Oct 2022 17:30:40 +0800 (CST)
Hi all,
    I am using synapps_6_1 and xxx module.
    Now I started the xxx ioc, sscan module was good, but motor was not.  And  I want to use the simulate Motor.
    Then I modified "common.iocsh" in xxx-R6-1/iocBoot/iocxxx, added following lines:
iocshLoad("$(MOTOR)/iocsh/allstop.iocsh", "P=$(PREFIX)")
dbLoadTemplate("$(MOTOR)/modules/motorMotorSim/iocs/motorSimIOC/iocBoot/iocMotorSim/motor.substitutions")
     It failed except the "AllStop Button" in xxx OPI.
     How should i do it, add the simMotor in xxx.
Liang
Re: add motor module in synapps Kevin Peterson via Tech-talk
Prev: EDM Local PV value in a shell command Abdalla Ahmad via Tech-talk
Next: Current open Controls positions at ITER Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: add motor module in synapps Kevin Peterson via Tech-talk
