1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: RE: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: "Marco A. Barra Montevechi Filho" <[email protected]>, "Mooney, Tim M." <[email protected]>, SOL <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 19 Oct 2022 15:06:03 +0000
I hadn’t noticed you were compiling for linux-arm on amd64, I think you’ll need to set CROSS_COMPILER_TARGET_ARCHS rather than EPICS_HOST_ARCH maybe something along the lines of https://epics-controls.org/resources-and-support/documents/howto-documents/cross-compile-epics-ioc-old-x86-linux/
Freddie
From: Marco A. Barra Montevechi Filho <[email protected]>
Sent: 19 October 2022 16:02
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; Mooney, Tim M. <[email protected]>; SOL <[email protected]>; [email protected]
Subject: Re: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db
Hi, Freddie!
I tried adding it to configure/CONFIG_SITE inside opcua-v0-9-3 but it still doesnt work:
opcua-v0-9-3/exampleTop/DeviceDbApp/S7-1500Db# make
make -C O.linux-arm -f ../Makefile TOP=../../.. \
    T_A=linux-arm install
make[1]: Entering directory '/usr/local/epics-nfs/modules/R7.0.5/synApps/R6.1/support/synApps/support/opcua-v0-9-3/exampleTop/DeviceDbApp/S7-1500Db/O.linux-arm'
Inflating database from ../S7-1500-server.substitutions
I. -I.. -I../O.Common -I../../../db -o S7-1500-server.db -S../S7-1500-server.substitutions
make[1]: I.: Command not found
make[1]: [/usr/local/epics-nfs/base/R7.0.5//configure/RULES.Db:477: ../O.Common/S7-1500-server.db] Error 127 (ignored)
mv: cannot stat 'S7-1500-server.db': No such file or directory
make[1]: *** [/usr/local/epics-nfs/base/R7.0.5//configure/RULES.Db:478: ../O.Common/S7-1500-server.db] Error 1
make[1]: Leaving directory '/usr/local/epics-nfs/modules/R7.0.5/synApps/R6.1/support/synApps/support/opcua-v0-9-3/exampleTop/DeviceDbApp/S7-1500Db/O.linux-arm'
make: *** [/usr/local/epics-nfs/base/R7.0.5//configure/RULES_ARCHS:58: install.linux-arm] Error 2
Should it be in cnofigure/CONFIG_SITE of synApps?
Marco
From: Freddie Akeroyd - STFC UKRI <[email protected]>
Sent: 19 October 2022 11:58
To: Mooney, Tim M. <[email protected]>; SOL <[email protected]>; Marco A. Barra Montevechi Filho <[email protected]>; [email protected] <[email protected]>
Hi Marco,
I think Tim is correct that the msi command has not been found. A version of MSI is shipped with EPICS 7, if it is not being picked up you may be able to just add
MSI = $(MSI3_15)
To e.g. configure/CONFIG_SITE
Freddie
From: Tech-talk <[email protected]> On Behalf Of Mooney, Tim M. via Tech-talk
Sent: 19 October 2022 15:37
To: [email protected]; SOL <[email protected]>; Marco A. Barra Montevechi Filho <[email protected]>
Hi Marco,
The tool that turns a .substitutions file into a .db file is MSI.  I think that's what's not being found.
MSI: Macro Substitution and Include Tool. MSI is a general purpose macro substitution/include tool. It accepts as input an ascii template file. Documentation
epics.anl.gov
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <[email protected]>
Sent: Wednesday, October 19, 2022 8:44 AM
To: [email protected] <[email protected]>; SOL <[email protected]>
Subject: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db
Hello all. Im compiling synApps with EPICS base R7.0.5 for linux-arm. The base has already been compiled for linux-arm here. (details about arm compilation at the end of e-mail).
I got the synApps support from https://github.com/EPICS-synApps/support. I then defined my EPICS_BASE to point to the right directory and EPICS_HOST_ARCH=linux-arm. I also added $EPICS_BASE/bin/linux-arm to PATH and $EPICS_BASE/lib/linux-arm to LD_LIBRARY_PATH. I edited EPICS_BASE inside assemble_synApps.sh to point to the right location.
In the compilation process i needed to install libnet-dev, libpcap0.8-dev and libusb-dev, all without trouble.
Now, inside synApps/support/opcua-v0-9-3/exampleTop/DeviceDbApp/S7-1500Db, when i run make i get the following error message:
/usr/local/epics-nfs/modules/R7.0.5/synApps/R6.1/support/synApps/support/opcua-v0-9-3/exampleTop/DeviceDbApp/S7-1500Db# make
2 things here make me curious: make[1]: I.: Command not found and mv: cannot stat 'S7-1500-server.db': No such file or directory
The "command not found" makes no sense to me at all. I tried following the Makefiles and includes to find where is the problematic command comming from but i couldnt find it. Im not fluent in make so i might be missing something silly.
The 'S7-1500-server.db': No such file or directory makes more sense to me: after cd into the opcua-v0-9-3 module and doing ´find -iname S7-1500-server.db´ i find nothing. I also find nothing with this name below EPICS base. Am i misunderstanding something or is this .db file actually missing?
Im compilng synApps just to get AreaDetector anyway, so i suppose i can just comment out opcua from my support/configure/RELEASE?
Thanks for any help,
Marco
Obs: details about arm compilation
The IOCs from this base and synApps are going to run in an arm machine, but the compilation is being made in a container hosted in an amd machine. Inside the container, uname -a returns:
Linux sol7-linux 4.9.0-11-amd64 #1 SMP Debian 4.9.189-3+deb9u2 (2019-11-11) x86_64 GNU/Linux
but i configured EPICS_HOST_ARCH=linux-arm
The base compiled with no problem.
I did this because we have a few arm machines in here and their EPICS_HOST_ARCH was defined this way. Am i forgetting anything important? Should just defining this env var make the compilation work for arm even if the host is amd?
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
Re: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Marco A. Barra Montevechi Filho via Tech-talk
Re: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Mooney, Tim M. via Tech-talk
RE: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Marco A. Barra Montevechi Filho via Tech-talk
Next: RE: Db/Makefile infinite loop Pearson, Matthew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: Help compiling synApps for linux-arm: opcua missing S7-1500-server.db Marco A. Barra Montevechi Filho via Tech-talk
