You did not tell us what the actual problem is. Does it fail to compile, or give a runtime error, or give the “wrong” result?
Sent from my iPhone
> On Oct 20, 2022, at 10:06 AM, Meddage, Varuna via Tech-talk <[email protected]> wrote:
> Hi,
> I have question about extracting PV value from a bo type record in EPICS through an external C++ program.
> If I explain the issue in detail,
> First I created a bo type record in one of the .db files. Then I was able to successfully change the value of this record using CS - studio GUI using an on/off switch. (used ca_get command to confirm whether the PV value is changed, when I toggle the on/off switch in CSS GUI)
> ////////////////////////////////////////// This is the b0 type record in my .db file ///////////////////////
> record(bo,"$(detector)_wib$(crate)0$(wib)_femb$(femb)/switch")
> field(DTYP,"")
> field(OUT,"CA_LINK")
> field(SCAN,"Passive")
> field(DESC,"Status")
> field(ZSV,"MAJOR")
> field(OSV,"NO_ALARM")
> field(ZNAM,"Off")
> field(ONAM,"On")
> But when I try to extract the value of this PV through an external C++ program, using ca_get command, I cannot do that successfully.
> /////////////////////////////////////////////////// rough outline of the C++ program used to extract PV value ///////////////
> chid femb[N_FEMB_PV];
> int status;
> std::cout << "********************** FEMB sensor summmary ************************** \n";
> for(int i=0; i<N_FEMB_PV; i++) {
> sprintf(femb_pv[i], femb_pv_pattern[i]);
> printf("%s\n", femb_pv[i]);
> status = ca_create_channel(femb_pv[i], NULL, NULL, 0, &femb[i]);
> SEVCHK(status,"ca_create_channel error");
> status = ca_pend_io(1.0);
> SEVCHK(status,"ca_pend_io error");
> printf("PV: %s\n", ca_name(femb[i]));
> printf("State: %d\n", ca_state(femb[i]));
> printf("Host %s\n", ca_host_name(femb[i]));
> printf("Read: %d\n", ca_read_access(femb[i]));
> printf("Write: %d\n", ca_write_access(femb[i]));
> printf("Type: %s\n", dbr_type_to_text(ca_field_type(femb[i])));
> printf("Count: %d\n", ca_element_count(femb[i]));
> double femb_power_commands[96];
> for (int entry=0; entry<some_number; entry++){
> status = ca_get(DBR_DOUBLE,femb[entry],&femb_power_commands[entry]);
> Any advice to solve this issue is really appreciated.
> Thanks
> Varuna Meddage
- Re: Question about extracting information from a bo type record in EPICS Meddage, Varuna via Tech-talk
- Question about extracting information from a bo type record in EPICS Meddage, Varuna via Tech-talk
RE: Db/Makefile infinite loop Pearson, Matthew via Tech-talk
starting ImageJ/EPICS_AD_Viewer with specified PVPrefix John Dobbins via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
