1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Motor record: motion relative to .RBV
From: "Marco A. Barra Montevechi Filho via Tech-talk" <[email protected]>
Date: Fri, 28 Oct 2022 19:40:42 +0000
Hello all!
Im reading through the EPICS motor record to search for a field similar to .RLV. If i understand correctly, the .RLV will do something similar to summing the caputted value to .VAL instead of directly putting it into .VAL.
Is there a field that sums itself with .RBV instead and then puts this value into .VAL?
Example of expected behavior:
caget MOTOR.RBV
MOTOR.RBV         0.5
caget MOTOR.VAL
MOTOR.VAL         2  #Lets say that for some reason .VAL and .RBV are not in sync.
caput MOTOR.MISTERIOUS_FIELD 0.5
#wait for some time...
caget MOTOR.RBV
MOTOR.RBV            1
caget MOTOR.VAL
MOTOR.VAL             1
Sorry if the question is trivial but i couldnt find anything in the documentation. Thanks!
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Motor record: motion relative to .RBV Torsten Bögershausen via Tech-talk
Re: Motor record: motion relative to .RBV Kevin Peterson via Tech-talk
Prev: Software Engineer Position at APS Shen, Guobao via Tech-talk
Next: Re: Motor record: motion relative to .RBV Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
