1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Subject: Processing a record with asynPortDriver
From: "Sobhani, Alex via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 4 Nov 2022 18:45:17 +0000
I can use setIntegerParam(param, val); to change the value of a record,
and if val is different from the PV's current value, the record will get
processed. But if val is the same as the PV's current value the record
will not get processed. So if I want to process a record I have to find
out its current value using getIntegerParam, and then set it to
something other than this.
Is there a function that I can call like this: "processRecord(param);",
and it will just process the record associated with that param? I can
make one using the procedure I described in the previous paragraph but I
am sure there is a better way to do this.
Alex
Re: Processing a record with asynPortDriver Mark Rivers via Tech-talk
Prev: Re: MVME6100 booting error(putty) Heinz Junkes via Tech-talk
Next: Phoebus Alarm Log Table docs William F Badgett Jr via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024
Next: Re: Processing a record with asynPortDriver Mark Rivers via Tech-talk
ANJ, 04 Nov 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
