William, The parameters can change with the release of phoebus. The params you cite are valid in the older version I'm using tag parent-4.6.6, but in the latest/current release I believe those are not valid. Now, Kibani is used so the parms differ. The README for your particular version should have the correct parameter options.
Regards, -ps
FYI
The elastic-search connection parameters in the documentation are not correct. The code uses the following:
org.phoebus.applications.alarm.logging.ui/es_host=example.com
org.phoebus.applications.alarm.logging.ui/es_port=9201
and then Phoebus successfully connects to elastic search
Accelerator Division Controls
Neutrino Division Operations
Fermi National Accelerator Lab
Kirk and Wilson Roads
BTE-214 Booster Tower East Room 214
Batavia, IL 60510 U.S.A.
- Alarm Log Table in Phoebus William F Badgett Jr via Tech-talk
Re: [SPAM] Re: Processing a record with asynPortDriver Mark Rivers via Tech-talk
Command history in IOC EPICS Adrian Martinez via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 07 Nov 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
