1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: tech-talk <[email protected]>, 吴煊 <[email protected]>
Date: Mon, 14 Nov 2022 14:27:56 +0000
> Is there "Find/Replace" function still in phoebus? It's very useful for replacing pv names or other things in CSS. Another question I'd like to ask:how to create and write XML file in phoebus? I haven't see it in display builder examples. Any advice or suggestions will be grately appretiated
Yes, one advantage of the XML file format is that it allows creating or modifying theses files outside of the graphical editor.
We don't try to include a complete XML editor in phoebus, but you can easily add an OS-specific editor to the context menu so that you can then open a display file from the phoebus file browser via the context menu.
For example, on Linux you can add a reference to the plain "gedit" text editor like this, so it can then be used to open *.bob or *.opi files and for example perform PV name replacements:
org.phoebus.framework.workbench/external_app_text=Text Editor,txt|dat|tab|py|ini|def|db|xml|xsl|css|cmd|sh|st|log|out|md|tex|shp|bob|opi|pvs|edl,gedit
You could also register VS code or another more XML-aware editor just for *.bob like that.
For a general python package that generates display files outside of phoebus, see https://github.com/als-epics/phoebusgen
-Kay
Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Prev: Re: Disable PVs processing based on some condition Rolf Keitel via Tech-talk
Next: menuScan Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
Next: Re: Re: [EXTERNAL] Phoebus: Find/Replace and Write XML file 吴煊 via Tech-talk
