Hello, I could add and run two procServ processes using manage-proc add. I have the following queries 1) How do I add a log file or keep a port for logging with manage-procs. How do I specify the port type (tcp or uds) 2) How to link conserver with the procServ processes created by manage-procs 3) The option manage-procs -write-procs-cf -f 'filename' is generating a file with connection type as uds. How do I use this file to configure conserver service 4) I wanted to create a system service however wanted to access/manage it from the user account without using sudo. Is it possible? basically for 'manage-procs attach'. As I see that the manage-proc services created with sudo can only be listed by 'sudo manage-proc list'. Just 'manage-procs list' does not list the system processes Thank you and regards, Kuldeep
ANJ, 29 Nov 2022 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
