1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: StreamDevice redirection to ai record with ASLO question
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Zimoch Dirk (PSI)" <[email protected]>
Date: Mon, 12 Dec 2022 10:28:19 -0600
Dirk,
Thanks!  That worked.
Kevin
On 12/10/22 03:23, Zimoch Dirk (PSI) wrote:
Hi Kevin,
StreamDevice redirection works exactly like a link or a dbPut (which is what it uses). When you write into ai.VAL using a link, it will not apply ASLO. Neither will using a redirection do.
But your value is an integer (%u). Thus you can write into ai.RVAL and use „Raw Soft Channel“ in ai.DTYP and the ai will convert.
Yours
Dirk
StreamDevice redirection to ai record with ASLO question Kevin Peterson via Tech-talk
Re: StreamDevice redirection to ai record with ASLO question Zimoch Dirk (PSI) via Tech-talk
Prev: Re: How to: IOC reading information from file? Nariyoshi, Pedro via Tech-talk
Next: Re: How to: IOC reading information from file? Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: StreamDevice redirection to ai record with ASLO question Zimoch Dirk (PSI) via Tech-talk
Next: EPICS Qt 3.8.3 [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
