1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Checking CPU and memory usage for an IOC
From: Andrew Johnson via Tech-talk <[email protected]>
To: "Wang, Andrew" <[email protected]>, Simon Rose <[email protected]>, EPICS tech-talk <[email protected]>
Date: Wed, 21 Dec 2022 10:48:16 -0600
Hi Andy,
Yes, it looks like most of those device parameters do differ from the documentation that it links to. Unfortunately this particular module has been lacking a willing maintainer for more years than I care to think of, and there are quite a few things that need fixing — take a look at the issues and PRs, you might want to merge some of them into your local copy. The .db files that come with it do work, but they might provide records that your site might not need/want, so you'll probably want to use locally-modified versions of them.
- Andrew
On 12/20/22 11:55 PM, Wang, Andrew via Tech-talk wrote:
All,
I was able to get iocStats working. However, there is a slight error in this document under the ao record section: https://www.slac.stanford.edu/grp/ssrl/spear/epics/site/devIocStats/README_devIocStats
Shouldn't cpuScanRate be cpu_scan_rate?
Thank you,
Andy
cpuScanRate
Sent: Monday, December 12, 2022 5:58 PM
To: Simon Rose <[email protected]>; EPICS tech-talk <[email protected]>
Subject: RE: Checking CPU and memory usage for an IOC
Thank you Simon!
Sent: Monday, December 12, 2022 2:34 PM
To: Wang, Andrew <[email protected]>; EPICS tech-talk <[email protected]>
Hi Andy –
There is the iocStats module that might do what you are looking for: https://github.com/epics-modules/iocStats.
In particular, there is a record that specifically monitors CPU usage: https://github.com/epics-modules/iocStats/blob/master/iocAdmin/Db/ioc.template#L130 (as well as one for memory usage).
Cheers,
Simon
From: Tech-talk <[email protected]> on behalf of "Wang, Andrew via Tech-talk" <[email protected]>
Reply to: "Wang, Andrew" <[email protected]>
Date: Monday, 12 December 2022 at 23:13
To: EPICS tech-talk <[email protected]>
Subject: Checking CPU and memory usage for an IOC
All,
This is a very general question, but I was curious if people here have been able to monitor CPU and memory usage of a particular IOC as it ran. If so, what was the approach you took to do so?
Thank you,
Andy
Complexity comes for free, Simplicity you have to work for.
Re: Checking CPU and memory usage for an IOC Simon Rose via Tech-talk
Checking CPU and memory usage for an IOC Wang, Andrew via Tech-talk
RE: Checking CPU and memory usage for an IOC Wang, Andrew via Tech-talk
Re: Checking CPU and memory usage for an IOC Wang, Andrew via Tech-talk
Prev: Re: Checking CPU and memory usage for an IOC Wang, Andrew via Tech-talk
Next: Re: Checking CPU and memory usage for an IOC Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
