1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Possible to create aliases for record fields?
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "Li, Ji" <[email protected]>
Date: Wed, 28 Dec 2022 11:47:38 +0000
At the moment, that is not possible. I had planned for quite some time to implement that. But I don‘t know what the core developers think of this.
Dirk
Am 20.12.2022 um 19:50 schrieb Li, Ji via Tech-talk <[email protected]>:
I'm trying to access record fields as PVs using alias command, such as:
alias("det1.NELM", "det1:NELM")
alias("det1.TSEN", "det1:TSEN")
The IOC didn't report errors, but apparently they all pointed to det1 as the change to det1 appeared on these aliases, and vice versa, and this was proved by dbla.
If alias command is not the right choice, are there any ways to create aliases/dummy PVs for fields?
Best,
-Ji Li
Possible to create aliases for record fields? Li, Ji via Tech-talk
Prev: RE: Transform record behavior Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: Possible to create aliases for record fields? Li, Ji via Tech-talk
Next: Mailing lists and APS Website down-time Andrew Johnson via Tech-talk
