1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: linux kernel module for mrfioc2 on MTCA
To: 문건영(선형가속기팀) <[email protected]>
Date: Wed, 4 Jan 2023 22:00:21 -0800
The actual kernel driver is located in
There are several methods you may try, here is also very old repo, but you can find "dkms" information there.
Best,
Han
On Wed, Jan 4, 2023 at 9:57 PM Han Lee <[email protected]> wrote:
Hi Geonyeong,
Please use the kernel driver for mrfiioc2 instead of what you used.
PCIID is not up-to-date, if you want to see through lspci, please check my own archived repo.
HTH,
Han
On Wed, Jan 4, 2023 at 9:41 PM 문건영(선형가속기팀) via Tech-talk <[email protected]> wrote:
Dear All,
I am trying to MTCA-EVG-300 and MTCA-EVR-300U are working on Linux using mrfioc2.
But, the following error is displayed:
epics> mrmEvgSetupPCI("EVG",08,00,0)
Can't open /sys/module/mrf/parameters/interfaceversion in order to read kernel module interface version. Kernel module not loaded or too old.
I used the latest version driver provided by MRF. https://github.com/jpietari/mrf-linux-driver
Do I have to use a driver other than this one?
The mrf directory does not exist In the /sys/module directory.
Instead, pci_mrfevg, pci_mrfevr exists.
# ls /sys/module/pci_mrfev*
/sys/module/pci_mrfevg:
coresize   holders    initstate  refcnt     taint
drivers    initsize   notes      sections   uevent
/sys/module/pci_mrfevr:
# lsmod
Module                  Size  Used by    Tainted: G
pci_mrfevr             57344  0
pci_mrfevg             53248  0
nfsv3                  28672  1
nfs                   135168  2 nfsv3
lockd                  77824  2 nfsv3,nfs
grace                  16384  1 lockd
sunrpc                196608  6 nfsv3,nfs,lockd
x86_pkg_temp_thermal    16384  0
igb                   184320  0
# ls /dev/e*
/dev/ega0  /dev/ega2  /dev/era0  /dev/era2  /dev/erb0  /dev/erb2
/dev/ega1  /dev/ega3  /dev/era1  /dev/era3  /dev/erb1  /dev/erb3
# dmesg | tail
Event Generator PCI/PCIe driver exiting.
Event Receiver PCI/PCIe driver exiting.
Event Generator PCI/PCIe driver init.
mrfevg:BAR0 start df000000 end df07ffff mmaped 41180000
udevd[165]: specified group 'mrf' unknown
Event Receiver PCI/PCIe driver init.
mrfevr:BAR0 start df200000 end df23ffff, mmap 40780000
mrfevr: Device Type: MTCAEVR300
mrfevr:BAR0 start df100000 end df13ffff, mmap 41040000
Best regards,
Geonyeong Mun
Jeong Han Lee, Dr.rer.nat
Staff Scientist and Engineer
Lawrence Berkeley National Laboratory
1 Cyclotron Road Mailstop 46R0161
Berkeley, CA 94720, United States
Tel :+1-510-486-6163
Cell:+1-510-384-3868
RE: linux kernel module for mrfioc2 on MTCA 문건영(선형가속기팀) via Tech-talk
Re: linux kernel module for mrfioc2 on MTCA Han Lee via Tech-talk
Prev: Re: linux kernel module for mrfioc2 on MTCA Han Lee via Tech-talk
Next: RE: linux kernel module for mrfioc2 on MTCA 문건영(선형가속기팀) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
