1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Scan rate '.01 second' not achievable
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Érico Nogueira Rolim <[email protected]>, "Barrett (US), Patrick E" <[email protected]>
Date: Sun, 8 Jan 2023 19:41:19 -0800
On 1/6/23 06:48, Érico Nogueira Rolim via Tech-talk wrote:
where quantum is determined by epicsThreadSleepQuantum().
On Linux, that function uses essentially '1.0 / sysconf ( _SC_CLK_TCK )'. The sysconf value is usually 100 (Hz), and it would explain why EPICS thinks it won't achieve the desired scan rate. I don't think a modern kernel will actually be limited by its tick rate, so I don't know how accurate that heuristic is.
The relevance of _SC_CLK_TCK on Linux these days is as eg. the multiplier for clock_t values
as returned by times() https://man7.org/linux/man-pages/man2/times.2.html
The association with the OS tick timer resolution depends on how the Linux kernel is configured.
These days tick-less (aka NO_HZ) is common.  Then _SC_CLK_TCK has no relation to timer resolution.
I can't speak to how this relates to HZ_PERIODIC configurations as might be selected with RTLinux.
So the "Scan rate '%s' is not achievable" warning can be ignored.  Almost...
There is a long standing oddity in the timer queue code where quantum/2 is subtracted from all
user provided delays.  This can result in a negative number, which is treated as 0 delay.
No one seems to recall why this is done.  imo. it is a bug.  Unfortunately it has been there
so long that some folks have come to depend on it.  eg. on vxWorks it otherwise isn't possible
to delay for only one tick.
https://github.com/epics-base/epics-base/blob/4b63882f283664bbe1ca152d44c5007ab23f55ce/modules/libcom/src/timer/timer.cpp#L68
From my testing, omitting the -quantum()/2 has no ill effects on Linux.
https://github.com/epics-base/epics-base/issues/106#issuecomment-1260232765
Notes:
In Linux kernel configuration, look for the "Timers subsystem" section.
eg. from a Debian 5.10 kernel configuration.
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
# CONFIG_NO_HZ is not set
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
# CONFIG_PREEMPT_NONE is not set
CONFIG_PREEMPT_VOLUNTARY=y
# CONFIG_PREEMPT is not set
For those wondering, on Linux the value returned for _SC_CLK_TCK actually comes from the
kernel via the magic "auxiliary vector" (cf. "AT_CLKTCK").
http://articles.manugarg.com/aboutelfauxiliaryvectors.html
$ /usr/bin/getconf CLK_TCK
100
$ LD_SHOW_AUXV=1 /bin/true | grep AT_CLKTCK
AT_CLKTCK:            100
Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
Scan rate '.01 second' not achievable Barrett (US), Patrick E via Tech-talk
Re: Scan rate '.01 second' not achievable Érico Nogueira Rolim via Tech-talk
Prev: Re: Scan rate '.01 second' not achievable Hu, Yong via Tech-talk
Next: Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
