1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Understanding Asyn-based motor controller driver
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Mon, 9 Jan 2023 10:42:51 +0000
Hi
I am trying to understand how a motor controller driver works and how the asynMotorController and Axis classes map to the EPICS motor record. For example, I am investigating this driver from ACS motion https://github.com/epics-motor/motorAcsMotion to see if it supports some functions from the motor record that are required by our data acquisition system. Here are my questions:
1.       motor jogging: since the class does not implement the “::moveVelocity” function, does this mean that the driver does not support jogging at all? Or it does at the low-level motor record interface?
2.       VELO and ACCL fields: The class uses different variables to hold acceleration and velocity information other than the base class’s variables “motorVelocity_” and “motorAccel_”. Does this mean that VELO and ACCL fields are useless? Same thing goes for the OFF field.
In other words, if a motor driver is based on the motor record, does this guarantee that all fields are functional and working with the controller? How to verify if a certain function not implemented in the asyn classes but working and implemented somewhere else?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME (Synchrotron-light for Experimental Science and Applications in the Middle East)
P.O. Box 7, Allan 19252, Jordan
Tel: +96253511348 , ext. 265
Fax: +96253511423
[email protected]
www.sesame.org.jo
RE: Understanding Asyn-based motor controller driver Abdalla Ahmad via Tech-talk
Re: Understanding Asyn-based motor controller driver Mark Rivers via Tech-talk
Prev: Re: linux kernel module for mrfioc2 on MTCA Michael Davidsaver via Tech-talk
Next: Help: Asyn record getting incomplete input Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
Next: RE: Understanding Asyn-based motor controller driver Abdalla Ahmad via Tech-talk
