1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Scan rate '.01 second' not achievable
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Andrew Johnson <[email protected]>, Ricardo Cardenes <[email protected]>, Érico Nogueira Rolim <[email protected]>
Cc: "Barrett \(US\), Patrick E" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 9 Jan 2023 10:55:40 -0800
On 1/8/23 19:46, Michael Davidsaver wrote:
On 1/6/23 09:24, Andrew Johnson via Tech-talk wrote:
$ ./modules/libcom/test/O.darwin-aarch64/epicsThreadPerform
*The epicsThreadSleepQuantum() call returns 0.010000 sec.**
**This doesnt match the quantum estimate of 0.009273 sec within 1%.*
It takes 0.011298 micro sec to call epicsThreadGetIdSelf ()
epicsThreadPrivateGet() takes 0.005903 microseconds
In EPICS Base-3.15 the path to use is ./src/libCom/test/O.linux-x86_64/epicsThreadPerform but the output is identical. I don't particularly like the "doesn't match the quantum estimate ... within n%" language in the output, but those of you with a statistical background might recognize an attempt to be mathematically correct.
Thus on a Mac the value returned by epicsThreadSleepQuantum() is reasonably accurate, while on a fairly recent and fast Linux box the "minimum slumber interval" may be up to about 2 orders of magnitude smaller.
fyi. on my laptop (intel core i5) with a debian stable kernel (CONFIG_NO_HZ_IDLE)
$ ./modules/libcom/test/O.linux-x86_64/epicsThreadPerform ...
This doesnt match the quantum estimate of 0.000165 sec within 10%.
epicsThreadSleepQuantum() is indeed off by two orders of magnitude.
Worth noting that epicsTimeTest attempts to measure epicsThreadSleep(0)
and gets a smaller interval (62us vs 165us).
./modules/libcom/test/O.linux-x86_64/epicsTimeTest
# Resolution 1 ns
# epicsThreadSleep(0.0) Delta 61510 ns
# Small Delta 91 ns
Scan rate '.01 second' not achievable Barrett (US), Patrick E via Tech-talk
Re: Scan rate '.01 second' not achievable Érico Nogueira Rolim via Tech-talk
Re: Scan rate '.01 second' not achievable Ricardo Cardenes via Tech-talk
Re: Scan rate '.01 second' not achievable Andrew Johnson via Tech-talk
Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
Prev: Re: Help: Asyn record getting incomplete input Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Scan rate '.01 second' not achievable Michael Davidsaver via Tech-talk
