1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: areaDetector/ADPilatus
To: [email protected]
Cc: [email protected]
Date: Wed, 11 Jan 2023 10:44:56 +0800 (GMT+08:00)
Dear Mark,
Recently I try to compilation my areaDetector/ADPilatus, and I downloaded the ADPilatus module from https://github.com/areaDetector/ADPilatus.
I met these question when I make it.
Could you give me some advise. And I use 3.15, synapps6-0, asyn-R4-33.
[guest@localhost ADPilatus]$ make clean
make -C ./configure clean
make[1]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/configure'
rm -rf O.linux-x86_64 O.Common
make[1]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/configure'
make -C ./pilatusApp clean
make[1]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp'
make -C ./src clean
make[2]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp/src'
make[2]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp/src'
make -C ./Db clean
make[2]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp/Db'
make[2]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp/Db'
make -C ./op clean
make[2]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp/op'
rm -f
make[2]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp/op'
make[1]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp'
make -C ./iocs clean
make[1]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs'
make -C ./pilatusIOC clean
make[2]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC'
make[3]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/configure'
make[3]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/configure'
make[3]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/pilatusApp'
make -C ./src clean
make[4]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/pilatusApp/src'
make[4]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/pilatusApp/src'
make[3]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/pilatusApp'
make -C ./iocBoot clean
make[3]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/iocBoot'
make -C ./iocPilatus clean
make[4]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/iocBoot/iocPilatus'
rm -f cdCommands envPaths dllPath.bat relPaths.sh
make[4]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/iocBoot/iocPilatus'
make[3]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/iocBoot'
make[2]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC'
make[1]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs'
make -C ./configure install
perl -CSD /home/guest/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/configure/O.linux-x86_64'
perl -CSD /home/guest/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/configure/O.linux-x86_64'
make -C ./pilatusApp install
make -C ./src install
perl -CSD /home/guest/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/guest/EPICS/synApps/support/asyn-R4-33/include     -I/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADSupport/include/os/Linux -I/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADSupport/include   -I/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADCore/include -I/home/guest/EPICS/epics-base/include/compiler/gcc -I/home/guest/EPICS/epics-base/include/os/Linux -I/home/guest/EPICS/epics-base/include     -I../../../pilatusApp/cbfSrc    -MM -MF pilatusDetector.d  ../pilatusDetector.cpp
make[3]: Leaving directory `/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADPilatus/pilatusApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/guest/EPICS/synApps/support/asyn-R4-33/include     -I/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADSupport/include/os/Linux -I/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADSupport/include   -I/home/guest/EPICS/synApps/support/areaDetector-R3-3-1/ADCore/include -I/home/guest/EPICS/epics-base/include/compiler/gcc -I/home/guest/EPICS/epics-base/include/os/Linux -I/home/guest/EPICS/epics-base/include     -I../../../pilatusApp/cbfSrc    -c ../pilatusDetector.cpp
../pilatusDetector.cpp:23:20: fatal error: cbf_ad.h: No such file or directory
 #include <cbf_ad.h>
compilation terminated.
make[3]: *** [pilatusDetector.o] Error 1
make[2]: *** [install.linux-x86_64] Error 2
make[1]: *** [src.install] Error 2
make: *** [pilatusApp.install] Error 2
Re: areaDetector/ADPilatus Mark Rivers via Tech-talk
Prev: Re: asyn Mark Rivers via Tech-talk
Next: Re: areaDetector/ADPilatus Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
