Hello Oscar
Many years ago, we happened to use the RDB archive engine so I will give you what I remember from that time. The RDB archive engine is a server application installed on a separate server. Once configured, the engine will start save samples from the configured PVs. The role of CSS/Phoebus is that it contains the data browser tool. The data browser tool connects to the archive engine via the preferences and configurations you mentioned, then you can view archived data on the data browser tool. The archive engine is a java application consisting of two tools, the config tool and the engine. The config tool is used to load PV configuration into the RDB and the engine tool is used to start the archiver itself. Unfortunately I could not find download links for it.
Hope this helps.
Abdalla.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Oscar Ibañez via Tech-talk
Sent: Thursday, January 12, 2023 11:03 AM
To: [email protected]
Subject: EPICS, PostgreSQL, Archive Engine: doubts about how to use them
I am trying to set up a PostgreSQL RDMS to work together with EPICS to save some PV values. However, I am having doubts about how to do it, since the process is not clear to me.
First of all, I installed EPICS and I downloaded Phoebus. Both are running with no problem. In addition, I installed PostgreSQL. It seems to work fine. Then, I tried to learn how to connect EPICS and PostgreSQL, and I ended up reading Phoebus documentation about the RDB Archive Engine, and that was the point when I did no understand what I was doing.
https://control-system-studio.readthedocs.io/en/latest/services/archive-engine/doc/index.html
The document says that I need to download the archive engine from:
https://controlssoftware.sns.ornl.gov/css_phoebus
But I can't find any archive engine in that place.
In addition, I am confused about the rol of Phoebus in this problem. Why do I need to set up any preference in the Phoebus configuration to use the Archive Engine? Phoebus is just a software to create and to display graphical screen to monitor/check the control system. If I run the Archive Engine, that software will save PV values in the PostgreSQL tables that I want. So, I don't understand the relationship between Phoebus and the Archive Engine, since the documentation is in the CSS web.
Any help would be useful.
Regards.
Óscar
- Re: EPICS, PostgreSQL, Archive Engine: doubts about how to use them Kasemir, Kay via Tech-talk
- EPICS, PostgreSQL, Archive Engine: doubts about how to use them Oscar Ibañez via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
