Hi, I've been trying to build SynApps but the build fails at some point while compiling the ADSimDetector module in areaDetector. I've looked at the error for a while and I don't really know what's causing it. It looks to me like a problem with the folder MakeFiles but this is my first time working on it so I'm not really sure. I'm using version R3-11 of areaDetector and here is the last part of the make output: make -C /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector install make[2]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector' make -C ./configure install make[3]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/configure' perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../.. mkdir -p O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../.. \ T_A=linux-x86_64 install make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/configure/O.linux-x86_64' perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/configure/O.linux-x86_64' make[3]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/configure' make -C ./simDetectorApp install make[3]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp' make -C ./src install make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/src' perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir -p O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[5]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/src/O.linux-x86_64' /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/martin/EPICS/support/synApps/support/asyn-R4-42/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include/os/Linux -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/include -I/home/martin/EPICS/epics-base/include/compiler/gcc -I/home/martin/EPICS/epics-base/include/os/Linux -I/home/martin/EPICS/epics-base/include -MM -MF simDetector.d ../simDetector.cpp /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/martin/EPICS/support/synApps/support/asyn-R4-42/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include/os/Linux -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/include -I/home/martin/EPICS/epics-base/include/compiler/gcc -I/home/martin/EPICS/epics-base/include/os/Linux -I/home/martin/EPICS/epics-base/include -c ../simDetector.cpp ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = signed char]’: ../simDetector.cpp:624:46: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = unsigned char]’: ../simDetector.cpp:627:47: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = short int]’: ../simDetector.cpp:630:47: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = short unsigned int]’: ../simDetector.cpp:633:48: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = int]’: ../simDetector.cpp:636:47: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = unsigned int]’: ../simDetector.cpp:639:48: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = long long int]’: ../simDetector.cpp:642:47: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = long long unsigned int]’: ../simDetector.cpp:645:48: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = float]’: ../simDetector.cpp:648:49: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = double]’: ../simDetector.cpp:651:49: required from here ../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 68 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 72 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = signed char]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = signed char]’ ../simDetector.cpp:624:46: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] 225 | for (i=0; i<arrayInfo_.nElements; i++) { | ~^~~~~~~~~~~~~~~~~~~~~ ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = unsigned char]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = unsigned char]’ ../simDetector.cpp:627:47: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = short int]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = short int]’ ../simDetector.cpp:630:47: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = short unsigned int]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = short unsigned int]’ ../simDetector.cpp:633:48: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = int]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = int]’ ../simDetector.cpp:636:47: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = unsigned int]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = unsigned int]’ ../simDetector.cpp:639:48: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = long long int]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = long long int]’ ../simDetector.cpp:642:47: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = long long unsigned int]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = long long unsigned int]’ ../simDetector.cpp:645:48: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = float]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = float]’ ../simDetector.cpp:648:49: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] ../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = double]’: ../simDetector.cpp:94:55: required from ‘int simDetector::computeArray(int, int) [with epicsType = double]’ ../simDetector.cpp:651:49: required from here ../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare] /usr/bin/ar -rc libsimDetector.a simDetector.o /usr/bin/ranlib libsimDetector.a /usr/bin/g++ -o libsimDetector.so -shared -fPIC -Wl,-hlibsimDetector.so -L/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/lib/linux-x86_64 -L/home/martin/EPICS/epics-base/lib/linux-x86_64 -L/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/lib/linux-x86_64 -L/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/lib/linux-x86_64 -L/home/martin/EPICS/support/synApps/support/asyn-R4-42/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/epics-base/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/support/synApps/support/asyn-R4-42/lib/linux-x86_64 -rdynamic -m64 simDetector.o -lADBase -lasyn -lntndArrayConverter -lnt -lpvDatabase -lpvAccess -lpvData -lnetCDF -lnanohttp_stream -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -ldbRecStd -ldbCore -lca -lCom -lX11 -lXext -lpthread -lreadline -lm -lrt -ldl -lgcc Installing shared library ../../../lib/linux-x86_64/libsimDetector.so Installing library ../../../lib/linux-x86_64/libsimDetector.a make[5]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/src/O.linux-x86_64' make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/src' make -C ./Db install make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/Db' perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir -p O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[5]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/Db/O.linux-x86_64' make[5]: Nothing to be done for 'install'. make[5]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/Db/O.linux-x86_64' make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/Db' make -C ./op install make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/op' make[4]: Nothing to be done for 'install'. make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/op' make[3]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp' make -C ./iocs install make[3]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs' make -C ./simDetectorNoIOC install make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC' make -C ./configure install make[5]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/configure' perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../.. mkdir -p O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../.. \ T_A=linux-x86_64 install make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64' perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64' make[5]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/configure' make -C ./simDetectorNoIOCApp install make[5]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/configure/RULES_USER make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/configure/RULES_USER'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 ../configure/CONFIG_SITE.linux-x86_64.Common make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '../configure/CONFIG_SITE.linux-x86_64.Common'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.linux-x86_64.Common make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.linux-x86_64.Common'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.linux-x86_64 make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.linux-x86_64'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.linux-x86_64. make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.linux-x86_64.'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.linux-x86_64 make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.linux-x86_64'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local. make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/support/synApps/support/configure/CONFIG_SITE.linux-x86_64. make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/configure/CONFIG_SITE.linux-x86_64.'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/configure/CONFIG_USER.linux-x86_64 make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/configure/CONFIG_USER.linux-x86_64'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/configure/CONFIG_USER make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/configure/CONFIG_USER'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/epics-base/configure/os/CONFIG_SITE.UnixCommon.Common make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/epics-base/configure/os/CONFIG_SITE.UnixCommon.Common'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/epics-base/configure/CONFIG_SITE.local make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/epics-base/configure/CONFIG_SITE.local'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/epics-base/configure/RELEASE.linux-x86_64.Common make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/epics-base/configure/RELEASE.linux-x86_64.Common'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/epics-base/configure/RELEASE.linux-x86_64 make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/epics-base/configure/RELEASE.linux-x86_64'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 ../configure/RELEASE.linux-x86_64.Common make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '../configure/RELEASE.linux-x86_64.Common'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 ../configure/RELEASE.local make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '../configure/RELEASE.local'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 ../RELEASE.local make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '../RELEASE.local'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 ../../../../../RELEASE.linux-x86_64.local make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '../../../../../RELEASE.linux-x86_64.local'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 ../../../../../RELEASE.local make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '../../../../../RELEASE.local'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -f ../Makefile TOP=../../.. T_A=linux-x86_64 /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/RELEASE_PRODS.local.linux-x86_64 make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/RELEASE_PRODS.local.linux-x86_64'. Stop. make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make -C ./src install make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src' perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../.. mkdir -p O.Common make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \ T_A=linux-x86_64 install make[7]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64' /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DUSE_TYPED_RSET -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I../../../../../include -I/home/martin/EPICS/support/synApps/support/asyn-R4-42/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include/os/Linux -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/include -I/home/martin/EPICS/support/synApps/support/autosave-R5-10-2/include/os/Linux -I/home/martin/EPICS/support/synApps/support/autosave-R5-10-2/include -I/home/martin/EPICS/support/synApps/support/busy-R1-7-3/include -I/home/martin/EPICS/support/synApps/support/calc-R3-7-4/include -I/home/martin/EPICS/support/synApps/support/seq-2-2-9/include -I/home/martin/EPICS/support/synApps/support/sscan-R2-11-5/include -I/home/martin/EPICS/support/synApps/support/iocStats-3-1-16/include/os/Linux -I/home/martin/EPICS/support/synApps/support/iocStats-3-1-16/include -I/home/martin/EPICS/support/synApps/support/alive-R1-3-1/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADPluginEdge/include -I/home/martin/EPICS/epics-base/include/compiler/gcc -I/home/martin/EPICS/epics-base/include/os/Linux -I/home/martin/EPICS/epics-base/include -MM -MF simDetectorNoIOC.d ../simDetectorNoIOC.cpp /usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -DUSE_TYPED_RSET -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I../../../../../include -I/home/martin/EPICS/support/synApps/support/asyn-R4-42/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include/os/Linux -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/include -I/home/martin/EPICS/support/synApps/support/autosave-R5-10-2/include/os/Linux -I/home/martin/EPICS/support/synApps/support/autosave-R5-10-2/include -I/home/martin/EPICS/support/synApps/support/busy-R1-7-3/include -I/home/martin/EPICS/support/synApps/support/calc-R3-7-4/include -I/home/martin/EPICS/support/synApps/support/seq-2-2-9/include -I/home/martin/EPICS/support/synApps/support/sscan-R2-11-5/include -I/home/martin/EPICS/support/synApps/support/iocStats-3-1-16/include/os/Linux -I/home/martin/EPICS/support/synApps/support/iocStats-3-1-16/include -I/home/martin/EPICS/support/synApps/support/alive-R1-3-1/include -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADPluginEdge/include -I/home/martin/EPICS/epics-base/include/compiler/gcc -I/home/martin/EPICS/epics-base/include/os/Linux -I/home/martin/EPICS/epics-base/include -c ../simDetectorNoIOC.cpp make[7]: *** No rule to make target '../../../lib/linux-x86_64/libopencv_core.a', needed by 'simDetectorNoIOCApp'. Stop. make[7]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64' make[6]: *** [/home/martin/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2 make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src' make[5]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: src.install] Error 2 make[5]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp' make[4]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: simDetectorNoIOCApp.install] Error 2 make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC' make[3]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: simDetectorNoIOC.install] Error 2 make[3]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs' make[2]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: iocs.install] Error 2 make[2]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector' make[1]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector.install] Error 2 make[1]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11' make: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: /home/martin/EPICS/support/synApps/support/areaDetector-R3-11.install] Error 2
ANJ, 02 Feb 2023 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
