1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Problems using Universal I/O
From: Jukka Pietarinen via Tech-talk <[email protected]>
To: dipirro <[email protected]>, [email protected]
Date: Thu, 26 Jan 2023 09:06:17 +0200
Hi Giampiero,
From the hardware point of view on the mTCA-EVR-300U the front panel Universal I/Os are configured/mapped through registers at offset 0x440-0x447 (Front Panel Universal I/O Mapping Registers) and the RTM Universal I/Os are mapped through registers at offset 0x480-0x493 (Transition Board Output Mapping Registers).
Unfortunately, I cannot help with configuring this through mrfioc2.
Jukka
On 1/25/23 4:53 PM, dipirro via Tech-talk wrote:
Hi, I have an mrf system set up as follows:
One mTCA-EVR-300 with 2 Universal I/O LVTTL Output UNIV-TTL and one mTCA.4 Rear Transition Module (mTCA-EVRTM-300) with 3 Universal I/O LVTTL Output UNIV
I installed mrfioc2 but I don't know how to configure it to allow the use of Universal I/O
Re: Problems using Universal I/O Timo Korhonen via Tech-talk
Problems using Universal I/O dipirro via Tech-talk
Prev: RE: EPICS deb/rpm packaging Abdalla Ahmad via Tech-talk
Next: RE: Strange memory leak with ADAravis Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Problems using Universal I/O dipirro via Tech-talk
Next: Re: Problems using Universal I/O Timo Korhonen via Tech-talk
