Subject: |
Re: Kernel showing segfaults in motorPoller. |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Thu, 26 Jan 2023 20:04:35 +0100 |
On Thu, 26 Jan 2023 at 19:02, Marco A. Barra Montevechi Filho via Tech-talk < [email protected]> wrote:
We are experimenting several segfaults with motor IOCs here. Behavior is unpredictable, but i suspect common cause.
Any tips on how to debug this?
Get core dumps. Most probably it's enough to set the core file size before running your IOC: You can always check the current limit with 'ulimit -a'. Then load the core file into gdb and have a look.
Cheers, ~Ralph
- Kernel showing segfaults in motorPoller. Marco A. Barra Montevechi Filho via Tech-talk
Re: Problems using Universal I/O Timo Korhonen via Tech-talk
<2023>
2025
2026
Re: Kernel showing segfaults in motorPoller. Marco A. Barra Montevechi Filho via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
