1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Minor Sequencer tests issue under EPICS 7.0.7
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 27 Jan 2023 13:10:03 +0100
All,
When compiled against EPICS Base 7.0.7, the test suite of the Sequencer fails if you "make runtests" a second time without "make clean" in between. (The linker complains about an undefined reference to "main".)
A simple fix restores the original behavior (patch attached and sent upstream).
This is entirely a problem of the unit tests, not of the sequencer itself.
There is no reason to update your installation unless you're facing the issue.
Cheers,
~Ralph
Attachment: seq-2.2.9-base707-fix.patch
Description: Binary data
Prev: Re: abdf1 driver that logs with logMsg? - I know this is a real long shot Maren Purves via Tech-talk
Next: REMINDER: EPICS Code-a-thon Collaboration Workshop - Book your space today Diamond Events via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Kernel showing segfaults in motorPoller. Ralph Lange via Tech-talk
Next: EPICS collaboration meeting - save the date Pierrick M Hanlet via Tech-talk
