1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Allen-Bradley PLC question
Date: Tue, 31 Jan 2023 17:30:30 +0000
Folks,
I have two old Allen-Bradley SLC 500 PLCs with the SLC 5/03 processors.  These are communicating with EPICS via the VME 6008-SV1 scanner card, which is connected to a 1747-DCM “Direct Communication Module” in the PLC.  These communicate via the Remote I/O (RIO) protocol.  We are planning to eliminate the VME crates on our beamline, but really hope to avoid spending the $50K or so that it would cost to replace the PLCs.
I am therefore looking for another way to communicate from EPICS to the PLCs. I am not aware of any device that replaces the VME 6008-SV1, for example a PCI-E card or an Ethernet adapter device.  Does anyone else know of one?
The SLC-5/03 has an RS-232 serial port 0 that normally uses the DF1 protocol.  It is how we program it from a PC, for example.  It also has an RS-485 port 1 that uses the DH-485 protocol.  It does not have an Ethernet connection.
The RS-232 port can be configured to use be a Modbus master.  Unfortunately it cannot be configured to be a Modbus slave, which would allow simple connection to EPICS via the Modbus module.  However, I could enhance the Modbus module to add support for acting as a Modbus slave, and the PLC could then connect to the EPICS IOC and send and receive data.
Does anyone know of another option, for example with the DH-485 port?
Re: Allen-Bradley PLC question Maren Purves via Tech-talk
Prev: Re: EPICS deb/rpm packaging Zhang, Tong via Tech-talk
Next: Re: Allen-Bradley PLC question Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Data transport problem with CA Jörn Dreyer via Tech-talk
