1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Phoebus server mode question
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>, Steve Kinder - STFC UKRI <steve.kinder at stfc.ac.uk>
Date: Wed, 1 Feb 2023 14:49:56 +0000
> If a particular bob file has already been used to start a GUI like this is there a way for following instances to pop that GUI up rather than starting a copy of it?
That's exactly what it does when I try it with
... -server 9876 -resource "/path/to/file.bob"
First time around it launches a new instance and opens that file.
Follow-up invocations direct the already running instance to open the file, or if it's already open, pop it to the front.
Details can vary if the resource is not recognized as being the same.
For example, if you already have it open as "/path/to/file.bob?MACRO=A" and then open "/path/to/file.bob?MACRO=B", that's a different thing.
And if you add special macros like "target=window", that might not be handled at this time.
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Steve Kinder - STFC UKRI via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, February 1, 2023 9:06 AM
Subject: [EXTERNAL] Phoebus server mode question
I am starting GUIs as separate windows via a server mode phoebus instance, as say the following example.
java -jar C:/phoebus/release/product.jar -server port -resource C:/path/to/file?target=window@widthxheight+x+y
Thanks
Steve
Phoebus server mode question Steve Kinder - STFC UKRI via Tech-talk
Prev: Phoebus server mode question Steve Kinder - STFC UKRI via Tech-talk
Next: Re: Allen-Bradley PLC question Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: looking for a spec for the MRF timing protocol Evans, Richard K. (GRC-H000) via Tech-talk
ANJ, 02 Feb 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
