1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Multiple sequencer instances undesirably sharing information
From: "Marco A. Barra Montevechi Filho via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: SWC <swc at lnls.br>
Date: Wed, 8 Feb 2023 21:35:45 +0000
Hello all. We created a sequencer state machine with EPICS_BASE 7.0.7, synApps6.2, Sequencer2-2-9.
The state machine controls a set of motors with the STOP, SPMG, VAL and RBV fields based on signals from a set of limit switches (not ideal to be done with IOC but it is what it is).
i instantiate it 9 times in my st.cmd file after iocInit:
seq SwitchesStates,"user=marco, BL=SOL:, HUTCH=S:, M=UltSoft:, N=1, BL2=SOL:, Setm=m1"
seq SwitchesStates,"user=marco, BL=SOL:, HUTCH=S:, M=UltSoft:, N=2, BL2=SOL:, Setm=m2"
seq SwitchesStates,"user=marco, BL=SOL:, HUTCH=S:, M=UltSoft:, N=9, BL2=SOL:, Setm=m9"
Every PV used in the .stt code has {N} or {Setm} in its name, so i can guarantee that i dont have multiple instances of state machine looking at the same PV.
I have 9 simulated motors: SOL:S:m1, SOL:S:m2, ..., SOL:S:m9.
Whenever i start my state machines, all motors go to the position that the last motor is in. For example, if i instantiate only the first 4 state machines and comment the last 5, then SOL:S:m1, SOL:S:m2, SOL:S:m3 will all go to SOL:S:m4.RBV.
The state machine is indeed programmed to send the motor to its own RBV with:
float m;
assign m to "{BL}{HUTCH}{M}Cmdm{N}"; //PV that has <MOTOR>.VAL in its OUT
monitor m;
float m_rbv;
assign m_rbv to "{BL}{HUTCH}{M}m{N}_RBV"; //Pv that has <MOTOR>.RBV in its INP
monitor m_rbv;
m = m_rbv;
pvPut(m);
but its supposed to be invisible between instances. Why is the last instance commanding everyone to follow it?
I tried adding <app_name>_SNCFLAGS += +r in the Makefile, but to no avail.
Thanks in advance for any hints
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Multiple sequencer instances undesirably sharing information Jemian, Pete R. via Tech-talk
Prev: Re: Weird behaviour in wait=True when using epics.Motor.get(something, something, wait=True) Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Multiple sequencer instances undesirably sharing information Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: PVXS on RTEMS (Re: PVXS release 1.3.0) Michael Davidsaver via Tech-talk
ANJ, 14 Dec 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
