1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Archiver appliance sampling buffer overflows after migration from Version 2018 to Version 1.1.0
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Tue, 14 Feb 2023 06:39:38 +0000
Re: Did I miss something for the migration or is there anything changed in the latest version?
The SCAN code has been reasonably stable for a couple of years now.
Re:  For example, the process frequency of PV A:B:C:D is 25Hz, the scan period is 1 second
For a 25Hz PV; shouldn't the sampling period be somewhat smaller? With a 1 second period you will lose at least 24 of the 25 samples.
I tested with simple ai record with an external process updating at about 100Hz archiving at SCAN/0.01 and I was able to store about 100 samples per second.
$ curl -s "http://localhost:17665/retrieval/data/getData.txt?pv=mshankar:arch:static1" | grep 22:20:11 | wc -l
108
$ curl -s "http://localhost:17665/retrieval/data/getData.txt?pv=mshankar:arch:static1" | grep 22:20:12 | wc -l
108
$ curl -s "http://localhost:17665/mgmt/bpl/getPVTypeInfo?pv=mshankar:arch:static1"
  "samplingPeriod": "0.01",
  "samplingMethod": "SCAN",
Murali
Prev: Archiver appliance sampling buffer overflows after migration from Version 2018 to Version 1.1.0 Wang, Lin via Tech-talk
Next: RE: Archiver appliance sampling buffer overflows after migration from Version 2018 to Version 1.1.0 Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Archiver appliance sampling buffer overflows after migration from Version 2018 to Version 1.1.0 Wang, Lin via Tech-talk
Next: RE: Archiver appliance sampling buffer overflows after migration from Version 2018 to Version 1.1.0 Wang, Lin via Tech-talk
