1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Help getting modbus module started
From: Pierrick M Hanlet via Tech-talk <[email protected]>
Date: Tue, 14 Feb 2023 19:02:33 +0000
Hi Christian,
You will also need to add some things to your xxxApp/src/Makefile:
- xxx_DBD+=modbusSupport.dbd
- xxx_DBD+=drvAsynSerialPort.dbd
- xxx_LIBS+=modbus
I think that this should do it for you.
Good luck,
Pierrick
On 2/14/23 11:38, Christian Pauly via Tech-talk wrote:
> Hi folks
> I am trying hard to set up a Raspberry running an EPICS IOC for a
> Delta VFD motor driver / frequency inverter. The device is controlled
> via modbus, using a large set of individual 16bit integer read/write
> registers for configuration, and few more registers for control.
> At the moment it is configured to talk Modbus ASCII via RS485, and
> with a simple Python program using minimalmodbus-lib i can talk to the
> controller.
> Now i started with a fresh EPICS 3.15.7 base, (in ~/EPICS/base) and
> installed ASYN-R4-43 (~/EPICS/modules/asyn-R4-43) and modbus
> (~/EPICS/modules/modbus_R3-2).
> I initiated a new application ~/EPICS/projects/FUcontrol,
> ran "makeBaseApp.pl -t example FUcontrol", "makeBaseApp.pl -i -t
> example FUcontrol" - and thats basically it.
> And now i am stuck how to include modbus (includes / libs / dbd files)
> into my exampleApp.
> I kind of managed to include ASYN already by adding
>   ASYN=... to the RELEASE file
> and to the Makefile:
>   FUcontrol_LIBS += asyn
> In my ioc startup st.cmd i can run the commands
> drvAsynSerialPortConfigure("RS485", "/dev/ttyUSB0", 0, 0, 0)
> to configure the interface.
> But if i add
> modbusInterposeConfig("RS485",2,1000,0)
> i get an error on startup claiming that modnusinterposeconfig can not
> be found.
> So:
> Is there any simple step-by-step instructions how to add modbus to an
> existing ioc application ?
> I could not find anything "simple" in the documentation. I saw the
> examples which come with modbus, but all these already look quite
> complicated to me...
> Or any good advise on how to continue from here ?
> Thanks for any help !
> Christian
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: Help getting modbus module started Pierrick M Hanlet via Tech-talk
RE: Help getting modbus module started Mark Rivers via Tech-talk
Help getting modbus module started Christian Pauly via Tech-talk
Prev: Help getting modbus module started Christian Pauly via Tech-talk
Next: Re: Help getting modbus module started Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
