1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Moxa terminal server question PROBLEM SOLVED
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 17 Feb 2023 13:41:07 -0800
On 2/17/23 13:02, Mark Rivers via Tech-talk wrote:
Folks,
I have solved the problem, and I can now program the SLC500 through the Moxa.
I enabled data logging on the Moxa and I saw that the received data from the PLC was identical to transmitted data to it.  I then found that this was true even when the PLC was off!  It was clearly a cable problem, as Mark K. suggested.
I misread the pinout of the RJ45 connector on the Moxa.  Interestingly, although EIA-561 specifies the pinout for RS-232 on RJ45, I have yet to find a vendor who actually follows the EIA-561 standard.  Moxa and ProSoft use a completely different pinout.
Fun right?  I used to keep a printout of this table on my desk @nsls2.
It wasn't exhaustive then, so I'm certain it isn't now.
https://www.conserver.com/consoles/Signals/signals.html
Moxa terminal server question Mark Rivers via Tech-talk
RE: Moxa terminal server question PROBLEM SOLVED Mark Rivers via Tech-talk
Prev: RE: Moxa terminal server question PROBLEM SOLVED Mark Rivers via Tech-talk
Next: node-epics-ca: A Channel Access client for Node.js (FFI implementation) Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Moxa Terminal Server question Koennecke Mark via Tech-talk
ANJ, 20 Feb 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
