1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: measComp R4-1 available
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 22 Feb 2023 00:28:21 +0000
Folks,
measComp R4-1 is available.  This is from the release notes:
  - Fixed problems with the E-DIO24 support that caused only bits 1-8 to work correctly, bits 9-24 did not work.
  - Added OPI screens for the E-DIO24.
  - Added substitutions files for the USB-3104.
  - Added support for the USB-1208FS-Plus and fixed some issues with the USB-1208FS and USB-1208LS.  Thanks to Wei Li from Duke for this.
  - Added support for the USB1608HS-2A0. Thanks to Zachary Arthur from CLS for this.
  - Changed to allow the uniqueId for Ethernet devices in MultifunctionConfig() to be an IP DNS name, in addition to the previously supported IP address or MAC address.
  - Moved the documentation to [Github Pages](https://epics-modules.github.io/measComp).
https://github.com/epics-modules/meascomp
Prev: Re: Re: Questions related to mcoreutil 김대영 via Tech-talk
Next: S7nodave for EPICS Manual White via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: Re: Questions related to mcoreutil Ralph Lange via Tech-talk
ANJ, 22 Feb 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
