1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: S7nodave for EPICS Manual
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, White <18019393607 at 163.com>
Date: Wed, 22 Feb 2023 19:12:47 +0000
Hi White,
What compiler are you using?  If it is gcc, what does "gcc --version" show?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of White via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, February 22, 2023 2:22 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: S7nodave for EPICS Manual
Recently, I was going to use the S7nodave to connect the PLC device,  There was a sentence in the manual that make me confused .
The manual said :S7nodave must be compiled with a C++ compiler that supports C++ 11. For some compilers, C++ 11 support is not enabled by default. In this case, you have to add the file configure/CONFIG_SITE.local and append the appropriate compiler options to the USR_CXXFLAGS variable. An example for such a configuration file can be found in configure/EXAMPLE_CONFIG_SITE.local.
I have two questions about this sentence:
     1. My computer's compiler does not support C++11, can I install boost insteal of c++ 11. Do I have to install C++ compiler that supports C++ 11?
     2. How to add the file configure/CONFIG_SITE.local and append the appropriate compiler options to the USR_CXXFLAGS variable, I haven't see any example.
Thanks
White
S7nodave for EPICS Manual White via Tech-talk
Prev: Re: S7nodave for EPICS Manual Simon Rose via Tech-talk
Next: Using asyn as a TCP socket client in AD ioc Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 22 Feb 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
