1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Segmentation fault (core dumped) using SimDetector ioc
To: "Mark Rivers" <[email protected]>
Date: Fri, 3 Mar 2023 17:50:39 +0800 (CST)
Hi Mark and all,
     I met "Segmentation fault" error when using SimDetector.
     I use rocky9(64) , asyn and areaDetector from git.
     When I executed st.cmd.linux. I got these as below:
lynn
Shell output:
epicsEnvSet("EPICS_CA_MAX_ARRAY_BYTES", "10000000")
# Create a simDetector driver
#simDetectorConfig(const char *portName, int maxSizeX, int maxSizeY, int dataType, int maxBuffers, int maxMemory, int priority, int stackSize)
simDetectorConfig("SIM1", 1024, 1024, 1, 0, 0)
Hereis st.cmd file:
epicsEnvSet("IOC","iocSimDetector")
epicsEnvSet("TOP","/opt/EPICS/synApps_6_1/support/areaDetector-master/ADSimDetector/iocs/simDetectorIOC")
epicsEnvSet("ADSIMDETECTOR","/opt/EPICS/synApps_6_1/support/areaDetector-master/ADSimDetector/iocs/simDetectorIOC/../..")
epicsEnvSet("SUPPORT","/opt/EPICS/synApps_6_1/support")
epicsEnvSet("ASYN","/opt/EPICS/synApps_6_1/support/asyn-R4-37")
epicsEnvSet("AREA_DETECTOR","/opt/EPICS/synApps_6_1/support/areaDetector-master")
epicsEnvSet("ADSUPPORT","/opt/EPICS/synApps_6_1/support/areaDetector-master/ADSupport")
epicsEnvSet("ADCORE","/opt/EPICS/synApps_6_1/support/areaDetector-master/ADCore")
epicsEnvSet("AUTOSAVE","/opt/EPICS/synApps_6_1/support/autosave-R5-10")
epicsEnvSet("BUSY","/opt/EPICS/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("CALC","/opt/EPICS/synApps_6_1/support/calc-R3-7-3")
epicsEnvSet("SNCSEQ","/opt/EPICS/synApps_6_1/support/seq-2-2-6")
epicsEnvSet("SSCAN","/opt/EPICS/synApps_6_1/support/sscan-R2-11-3")
epicsEnvSet("DEVIOCSTATS","/opt/EPICS/synApps_6_1/support/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/opt/EPICS/base")
errlogInit(20000)
dbLoadDatabase("$(TOP)/dbd/simDetectorApp.dbd")
simDetectorApp_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("PREFIX", "13SIM1:")
epicsEnvSet("PORT",   "SIM1")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "1024")
epicsEnvSet("YSIZE",  "1024")
epicsEnvSet("NCHANS", "2048")
epicsEnvSet("CBUFFS", "500")
epicsEnvSet("MAX_THREADS", "8")
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db")
#asynSetMinTimerPeriod(0.001)
simDetectorConfig("$(PORT)", $(XSIZE), $(YSIZE), 1, 0, 0)
# To have the rate calculation use a non-zero smoothing factor use the following line
#dbLoadRecords("simDetector.template",     "P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1,RATE_SMOOTH=0.2")
dbLoadRecords("$(ADSIMDETECTOR)/db/simDetector.template","P=$(PREFIX),R=cam1:,PORT=$(PORT),ADDR=0,TIMEOUT=1")
# Create a second simDetector driver
##simDetectorConfig("SIM2", 300, 200, 1, 50, 50000000)
##dbLoadRecords("$(ADSIMDETECTOR)/db/simDetector.template","P=$(PREFIX),R=cam2:,PORT=SIM2,ADDR=0,TIMEOUT=1")
# Load an NDFile database.  This is not supported for the simDetector which does not write files.
#dbLoadRecords("NDFile.template","P=$(PREFIX),R=cam1:,PORT=SIM1,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin, set it to get data from first simDetector driver.
NDStdArraysConfigure("Image1", 20, 0, "$(PORT)", 0, 0, 0, 0, 0, 5)
# This creates a waveform large enough for 2000x2000x3 (e.g. RGB color) arrays.
# This waveform only allows transporting 8-bit images
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=UCHAR,NELEMENTS=12000000")
# This waveform only allows transporting 16-bit images
#dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int16,FTVL=SHORT,NELEMENTS=12000000")
# This waveform allows transporting 32-bit images
#dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int32,FTVL=LONG,NELEMENTS=12000000")
# This waveform allows transporting 64-bit float images
#dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Float64,FTVL=DOUBLE,NELEMENTS=12000000")
# Load all other plugins using commonPlugins.cmd
< $(ADCORE)/iocBoot/commonPlugins.cmd# Create a standard arrays plugin, set it to get data from FFT plugin.
NDStdArraysConfigure("Image2", 3, 0, "FFT1", 0)
# This waveform allows transporting 64-bit images, so it can handle any detector data type at the expense of more memory and bandwidth
dbLoadRecords("NDStdArrays.template", "P=$(PREFIX),R=image2:,PORT=Image2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=FFT1,TYPE=Float64,FTVL=DOUBLE,NELEMENTS=12000000")
set_requestfile_path("$(ADSIMDETECTOR)/simDetectorApp/Db")
asynSetTraceIOMask("$(PORT)",0,2)
iocInit()
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P=$(PREFIX)")
Re: Segmentation fault (core dumped) using SimDetector ioc Mark Rivers via Tech-talk
Prev: RE: pasynOctetSyncIO error reading image status=4 Mark Rivers via Tech-talk
Next: Re: Segmentation fault (core dumped) using SimDetector ioc Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
