1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: Sphinx Github actions problem
To: "Yendell, Gary (DLSLtd,RAL,LSCI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 10 Mar 2023 00:03:03 +0000
Hi Gary,
Thanks very much!  I changed my .yml file to be similar to yours, and now it works fine.  I put the Doxygen output into docs/_build/html/doxygenHTML, and publish the docs/_build/html directory.  That avoids the conflict of the index.html files.  It is working for both a local build and the Github pages build.
From: Yendell, Gary (DLSLtd,RAL,LSCI) <[email protected]>
Sent: Thursday, March 9, 2023 4:31 AM
To: [email protected]; Mark Rivers <[email protected]>
Subject: Re: Sphinx Github actions problem
Hi Mark,
It looks like sphinx-notes/pages is doing what the peaceiris/actions-gh-pages [1] action does, with addition of running the sphinx build for you, but without actually deploying the branch it updates so that you have to do it manually. The latter is much more widely used.
I have a similar build of a project [2] using doxygen and sphinx that just runs `doxygen` and `sphinx-build -ET docs/ build/html/` directly and then uses the action like so:
      - name: Publish Docs
        if: github.event_name == 'push'
        # We pin to the SHA, not the tag, for security reasons.
        uses: peaceiris/actions-gh-pages@068dc23d9710f1ba62e86896f84735d869951305 # v3.8.0
        with:
          github_token: ${{ secrets.GITHUB_TOKEN }}
          publish_dir: build/html/
          keep_files: true
to deploy the build directory to GitHub Pages. It works pretty nicely.
[2] https://github.com/dls-controls/pmacFilterControl/blob/main/.github/workflows/docs.yml
Cheers,
Gary
From: Tech-talk <[email protected]> on behalf of Mark Rivers via Tech-talk <[email protected]>
Sent: 09 March 2023 00:30
To: [email protected] <[email protected]>
Folks,
I found a rather ugly solution.
·         I had Doxygen put its output in docs/doxygenHTML
·         I added these 2 lines to docs/source/conf.py
html_extra_path = ['../doxygenHTML']
exclude_patterns = ['index.html']
The first line tells Sphinx to copy all of the files in doxygenHTML/ to _build/html when it builds.  There seems to be no way to tell Sphinx to put the files in a subfolder, so there will be a conflict with index.html, which exists both for the Sphinx build and for the Doxygen build.  So the second line tells Sphinx to exclude copying the Doxygen index.html file.  In this specific case that is OK, because I had no useful information on the main Doxygen page, but in general this would be a serious issue.
I also had to add these lines to my Github Actions publish-docs.yml file after the Doxygen build:
    - name: Change Doxygen output permissions so Sphinx can delete
      run: |
        sudo chmod -R 777 docs/doxygenHTML
That is because Doxygen creates files owned by root, and Sphinx cannot delete them without changing their permissions.
It seems like there should be a better way to do this, so I am happy to hear any suggestions!
Sent: Wednesday, March 8, 2023 4:30 PM
Cc: Jemian, Pete R. <[email protected]>
Subject: Sphinx Github actions problem
Folks,
I am trying to build the asyn Web pages with Github Actions.  I need to do 2 things:
  • Run doxygen to build the source code documentation
  • Run Sphinx to build the human-generated documentation
Both of these work separately, but not together.  If I run the Doxygen build first, it generates the output files fine.  But then the Sphinx build (sphinx-notes/pages@v2) tries to delete all of the files that Doxygen generated.  I have tried having the Doxygen output go into the following locations:
/docs/doxygenOutput
/doxygenOutput
/docs/source/_static/doxygenOutput
In all cases Doxygen works fine, but then the Sphinx build tries to delete the Doxygen files.  The Sphinx build the actually fails because the doxygen generated files are owned by root. But even if it succeeded it would not work, since those files need to remain after the build.
If I run the Sphinx build first then Doxygen fails because the Sphinx build has already deleted the docs/ directory containing the Doxyfile.
Any idea solve this?
Sphinx Github actions problem Mark Rivers via Tech-talk
RE: Sphinx Github actions problem Mark Rivers via Tech-talk
Re: Sphinx Github actions problem Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Prev: RE: NDPluginXIP to compile the RIXSCam detector Mark Rivers via Tech-talk
Next: Re: Periodic SCAN issue in EPICS Archiver Appliance Vishnu Patel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Sphinx Github actions problem Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Next: Can not open more than one Phoebus instance at the same time javicruz--- via Tech-talk
