1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: areaDetector documentation changes
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 15 Mar 2023 13:37:47 +0000
Folks,
I have made the following changes to the areaDetector documentation.
Old
New
Home page
https://areaDetector.github.io/master
https://areaDetector.github.io/areaDetector
Build and install
Travis CI (areaDetector/.travis.yml)
Github Actions (areaDetector/.github/workflows/publish-docs.yml)
Sphinx theme
Bootstrap (sphinx-bootstrap-theme)
Read The Docs (sphinx-rtd-theme)
The old Travis job was no longer working.  The new system uses Github Pages for documentation.
The Read The Docs theme is nicer, because it gives a navigation panel on the left-hand side of each Web page.
I have changed all of the internal links, including the README.md files, to use the new URLs.  Any external sites that link to this documentation should be updated to replace areaDetector.github.io/master with areaDetector.github.io/areaDetector.
Please let me know of any issues with the new Web pages.
Prev: Re: How is EPICS used at your facility? bob dalesio via Tech-talk
Next: Re: How is EPICS used at your facility? Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: AW: How is EPICS used at your facility? Loeher, Bastian Dr. via Tech-talk
Next: Problem with PVA group def using .json file Ignacio Arriagada via Tech-talk
ANJ, 15 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
