1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Other approaches to disabling a record from processing if there is no connection?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 23 Mar 2023 15:08:51 +0100
Why do you want to disable records when the device is disconnected?
That's not a common thing to do, so I would like to see what's your motivation to try doing that.
Cheers,
~Ralph
Other approaches to disabling a record from processing if there is no connection? Wang, Andrew via Tech-talk
Prev: RE: Differences between using disconnectOnReadTime in asynSetOption and asyn record Wang, Andrew via Tech-talk
Next: EPICS Support for isel imc-s8 Axis-Controller Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Other approaches to disabling a record from processing if there is no connection? Wang, Andrew via Tech-talk
