1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Value of Renishaw absolute encoder exceeds its maximum
From: Chiang, Liang-Chih [江良志] via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 24 Mar 2023 03:32:30 +0000
Hello,
I use Galil DMC-4080 controller to read Renishaw absolute encoders(26 bits).
So far so good.
However, I conjectured that I encounter the situation where encoder's value
exceeds its maximum(2^26 = 67,108,864).
66,000,166 is the encoder value initially.
59,829,149 when going to negative limit switch, which is ok.
899,833 when going to positive limit switch, which is abnormal.
What could I do to handle this situation?
1.  Replace the encoder scale.
2.  Can I remedy it in EPICS? How? I have no idea.
Best regards.
LiangChih Chiang
NSRRC
Beamline Group
email:chiang.lc at nsrrc.org.tw
Re: Value of Renishaw absolute encoder exceeds its maximum Torsten Bögershausen via Tech-talk
Prev: RE: BiRa EMCOR vs. PCRC (aka. EPSC)? Liu, Wanming via Tech-talk
Next: Re: Value of Renishaw absolute encoder exceeds its maximum Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
ANJ, 24 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
