1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: GitHub's new rsa ssh host-key
From: Andrew Johnson via Tech-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>, EPICS Tech-talk <[email protected]>
Date: Fri, 24 Mar 2023 11:15:54 -0500
Hi Torsten,
On 3/24/23 10:07 AM, Torsten Bögershausen wrote:
I stumbled accross the same problem today.
I had over 100 emails in my inbox from our Jenkins CI-system about failing jobs because of this...
Why do you have 20 IP addresses ?
Shouldn't there simply be a hostname ?
That may be due to an architecture change on their side. In the past the github.com DNS entry had multiple IP addresses and the actual SSH server you talked to was picked at random from that list. Now it looks like there is only one IP address, and it's in a different range than the older addresses that appear in my known_hosts files. I'm deleting all of those other entries.
- Andrew
From: Tech-talk <[email protected]> on behalf of Andrew Johnson via Tech-talk <[email protected]>
Reply-To: Andrew Johnson <[email protected]>
Date: Friday, 24 March 2023 at 15:59
To: EPICS Tech-talk <[email protected]>
Subject: GitHub's new rsa ssh host-key
GitHub users note:
https://github.blog/2023-03-23-we-updated-our-rsa-ssh-host-key/
I actually have their original host-key on about 20 other IP addresses as well, the blog post doesn't mention those..
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: GitHub's new rsa ssh host-key Michael Davidsaver via Tech-talk
GitHub's new rsa ssh host-key Andrew Johnson via Tech-talk
Re: GitHub's new rsa ssh host-key Torsten Bögershausen via Tech-talk
Prev: Re: GitHub's new rsa ssh host-key Torsten Bögershausen via Tech-talk
Next: Re: GitHub's new rsa ssh host-key Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
