1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: RE: Encoder Stall happens when increasing direction of motor pulses is opposite of that of encoder count
From: "Pearson, Matthew via Tech-talk" <tech-talk at aps.anl.gov>
To: Chiang, Liang-Chih [江良志] <chiang.lc at nsrrc.org.tw>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 27 Mar 2023 14:22:44 +0000
Usually it’s best to try to keep MRES and ERES the same sign, which is overall less confusing. However, if you can’t do that, setting ERES negative is the correct solution, assuming you can’t reinstall the encoder so it’s the correct direction. Or, the motor direction could be changed so that it matches the encoder (which may also mean re-wiring the limits).
However, if you can’t fix the hardware, you have the encoder stall issue because the driver expect the encoder to be moving in the same direction as the motor. This check can be disabled either by disabling the encoder in the motor record (setting UEIP=No), or by setting the encoder tolerance to be a very high number. The encoder tolternace is a feature of the Galil driver, these two records:
$(P)$(M)_ENC_TOLERANCE_SP
If you set the tolerance to a large value (say 1,000,000) it will effectively disable the direction check.
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Chiang, Liang-Chih [???] via Tech-talk
Sent: Monday, March 27, 2023 4:58 AM
To: tech-talk at aps.anl.gov
Subject: [EXTERNAL] Encoder Stall happens when increasing direction of motor pulses is opposite of that of encoder count
Hello, EPICS mates,
I use Galil DCM 4080 motor controller and Renishaw absolute encoder.
When the increasing direction of motor pulses is opposite of that of encoder count,
which is, encoder count decreases while motor pulse increases,
my solution is to set motor record's ERES to be negative.
However, this solution will cause "Encoder Stall" problem.
The source of this problem cames from GalilAxis.cpp of Galil support module,
in the following function, encDirOk_ will be set to false because of opposite direction:
 void GalilAxis::setStatus(bool *moving)
    //Encoder direction ok flag
    encDirOk_ = (encoder_direction == direction_) ? true : false;
then in the following function, because of encDirOk_ is false,
after a period of time, it will be regards as "Encoder Stall" and stop motor.
//Called by poll without lock
//When encoder problem detected
//May stop motor via pollServices thread
void GalilAxis::checkEncoder(void)
    if (((ueip_ || ctrlUseMain_) && !done_ && !deferredMove_ && (!encoderMove_ || !encDirOk_)))
My questions are:
1. Is my solution "negative ERES" ok?
2.What would be a good fix to Galil support module? Just remove checking of encDirOk_?
Best regards.
LiangChih Chiang
NSRRC
Beamline Group
emailchiang.lc at nsrrc.org.tw
回覆: Encoder Stall happens when increasing direction of motor pulses is opposite of that of encoder count Chiang, Liang-Chih [江良志] via Tech-talk
Prev: Request for support: Error reading data in Epics Controls while modifying project Grzegorz Lak via Tech-talk
Next: Re: areadetector on windows, xml2 done, now Lightfield William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Encoder Stall happens when increasing direction of motor pulses is opposite of that of encoder count Chiang, Liang-Chih [江良志] via Tech-talk
Next: 回覆: Encoder Stall happens when increasing direction of motor pulses is opposite of that of encoder count Chiang, Liang-Chih [江良志] via Tech-talk
ANJ, 27 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
