1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: MEDM font alias woes on Ubuntu 22 (Jammy)
To: "Stein, Samuel Joshua" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Mar 2023 16:23:36 +0000
Hi Josh,
I just tried running medm on a Centos 7 machine and displaying on an Ubuntu 22 machine.  The first time I ran it I got messages about all of the missing widgetDM_* fonts.
I then edited /usr/share/fonts/X11/misc/fonts.alias and added these aliases at the end.  I got these lines from medm/medm/fonts.alias.sun
widgetDM_4      -misc-fixed-medium-r-normal--8-60-100-100-c-50-iso8859-1
widgetDM_6      -misc-fixed-medium-r-normal--8-60-100-100-c-50-iso8859-1
widgetDM_8      -misc-fixed-medium-r-normal--9-80-100-100-c-60-iso8859-1
widgetDM_10     -misc-fixed-medium-r-normal--10-100-75-75-c-60-iso8859-1
widgetDM_12     -misc-fixed-medium-r-normal--13-100-100-100-c-70-iso8859-1
widgetDM_14     -misc-fixed-medium-r-normal--14-110-100-100-c-70-iso8859-1
widgetDM_16     -misc-fixed-medium-r-normal--15-120-100-100-c-90-iso8859-1
widgetDM_18     -sony-fixed-medium-r-normal--16-120-100-100-c-80-iso8859-1
widgetDM_20     -misc-fixed-medium-r-normal--20-140-100-100-c-100-iso8859-1
widgetDM_22     -sony-fixed-medium-r-normal--24-170-100-100-c-120-iso8859-1
widgetDM_24     -sony-fixed-medium-r-normal--24-170-100-100-c-120-iso8859-1
widgetDM_30     -adobe-times-medium-r-normal--25-180-100-100-p-125-iso8859-1
widgetDM_36     -adobe-helvetica-medium-r-normal--34-240-100-100-p-176-iso8859-1
widgetDM_40     -adobe-helvetica-bold-r-normal--34-240-100-100-p-182-iso8859-1
widgetDM_48     -adobe-helvetica-bold-r-normal--34-240-100-100-p-182-iso8859-1
widgetDM_60     -adobe-helvetica-bold-r-normal--34-240-100-100-p-182-iso8859-1
I then restarted X11 with
sudo systemctl restart gdm
After doing that I was able to run medm and display on Ubuntu 22 with no missing font messages.  That actually surprised me, I expected to get some errors that there were missing fonts, and needing to install some system packages with the missing fonts.
I ran this command to list the installed X11 font packages:
sudo apt list –installed | grep fonts
and got this:
xfonts-100dpi/jammy,jammy,now 1:1.0.4+nmu1.1 all [installed]
xfonts-75dpi/jammy,jammy,now 1:1.0.4+nmu1.1 all [installed]
xfonts-base/jammy,jammy,now 1:1.0.5 all [installed]
xfonts-encodings/jammy,jammy,now 1:1.0.5-0ubuntu2 all [installed]
xfonts-scalable/jammy,jammy,now 1:1.0.3-1.2ubuntu1 all [installed]
xfonts-utils/jammy,now 1:7.7+6build2 amd64 [installed]
So if those font packages and the fonts.alias are set then it should work.
From: Tech-talk <[email protected]> On Behalf Of Stein, Samuel Joshua via Tech-talk
Sent: Tuesday, March 28, 2023 10:45 AM
To: [email protected]
Subject: MEDM font alias woes on Ubuntu 22 (Jammy)
TL;DR : Has anyone gotten an exported MEDM session to display properly on Ubuntu 22.04?
I am trying to get the font aliases working for MEDM running on a remote machine but exporting the display to a local Ubuntu (22.04) machine. The guide I found (https://www.slac.stanford.edu/grp/ssrl/spear/epics/extensions/medm/MEDM.html#Fonts) regarding font alias creation got me close, but given the way the newest version of Ubuntu seems to handle fonts, I can't seem to get it working.
When medm is invoked, I get the following alias errors:
medmInit: Unable to load font widgetDM_30
  Trying default (fixed) instead
medmInit: Unable to load font widgetDM_36
medmInit: Unable to load font widgetDM_40
medmInit: Unable to load font widgetDM_48
medmInit: Unable to load font widgetDM_60
Note that these fonts in the alias file appear to be pointing to adobe flavors, which may be an issue.
Re: MEDM font alias woes on Ubuntu 22 (Jammy) Stein, Samuel Joshua via Tech-talk
Prev: Re: MEDM font alias woes on Ubuntu 22 (Jammy) Pete Jemian via Tech-talk
Next: RE: Links between bob files in different support modules Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: MEDM font alias woes on Ubuntu 22 (Jammy) Stein, Samuel Joshua via Tech-talk
