1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: How do I setEPICS opc UA security Settings?
To: [email protected]
Date: Wed, 29 Mar 2023 20:49:20 +0800 (GMT+08:00)
Hi:
When I set up the EPICS OPC UA client, the server did not receive the reject (.der) file, but I did receive certificates from the server.
Here's how I set it up.
picsEnvSet("IOC","iocS7-1500")
epicsEnvSet("TOP","/root/epics-opcua/binaryOpcuaIoc")
epicsEnvSet("OPCUA","/root/epics-opcua/binaryOpcuaIoc/..")
epicsEnvSet("EPICS_BASE","/root/epics-opcua/base-7.0.6.1")
cd "/root/epics-opcua/binaryOpcuaIoc"
dbLoadDatabase "dbd/opcuaIoc.dbd"
opcuaIoc_registerRecordDeviceDriver pdbbase
## Pretty minimal setup: one session with a 200ms subscription on top
opcuaSession OPC1 opc.tcp://192.168.0.11:4853
opcuaSubscription SUB1 OPC1 200
# Switch off security
# opcuaOptions OPC1 sec-mode=None
opcuaOptions OPC1 sec-mode=best
opcuaSetupPKI /root/epics-opcua/pki
#opcuaClientCertificate /root/epics-opcua/pki /root/epics-opcua/pki
opcuaSaveRejected  /root/epics-opcua/pki1
## Load the databases for one of the examples
## Siemens S7-1500 PLC
#dbLoadRecords "db/S7-1500-server.db", "P=OPC:,R=,SESS=OPC1,SUBS=SUB1"
dbLoadRecords "db/S7-1500-DB1.db", "P=OPC:,R=DB1:,SESS=OPC1,SUBS=SUB1"
#dbLoadRecords "db/my.db", "P=OPC:,R=DB1:,SESS=OPC1,SUBS=SUB1"
iocInit
Starting iocInit
## EPICS R7.0.6.1
## Rev. 2023-03-21T05:11+0800
OPC UA Client Device Support 0.9.4 (-); using Unified Automation C++ Client SDK v1.5.5-355
OPC UA: Autoconnecting sessions
OPC UA Session OPC1: configured client certificate is not valid (expired?)
OPC UA session OPC1: connect service failed with status BadCertificateUntrusted
## Start any sequence programs
#seq sncopcuaIoc,"user=ralph"
epics> OPC UA Session OPC1: configured client certificate is not valid (expired?)
What should I do to create a client certificate? Should the client certificate be copied to the server?
Any suggestions/solution approaches are welcome.
Best Regards,
yinglei Tan
谭映雷
中国科学院高能物理研究所
电话:010-88235426
谭映雷 中国科学院高能物理研究所 电话:010-88235426
Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
Prev: Re: Keithley DMM6500 Henrique Silva via Tech-talk
Next: RE: areadetector on windows, xml2 done, now Lightfield Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
