1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: epics synapps asyn compile error
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Thu, 13 Apr 2023 17:25:15 +0900
I’d like to compile epics synapps asyn package, it shows an error even I uncomment this line in configure/CONFIG_SITE : #TIRPC=YES,
And install libtirpc-devel(sudo yum install libtirpc-devel)
Error:
make[2]: rpcgen: Command not found
cp ../vxi11/vxi11core.rpcl .
rpcgen  vxi11core.rpcl
make[2]: *** No rule to make target 'vxi11core_xdr.c', needed by 'vxi11core_xdr.o'.  Stop.
make[2]: Leaving directory '/usr/local/epics/main/modules/synApps/support/asyn-R4-40/asyn/O.linux-x86_64'
make[1]: *** [/usr/local/epics/main/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/usr/local/epics/main/modules/synApps/support/asyn-R4-40/asyn'
make: *** [/usr/local/epics/main/base/configure/RULES_DIRS:85: asyn.install] Error 2
Do you know how can I compile asyn package without this error?
Re: epics synapps asyn compile error Mark Rivers via Tech-talk
Prev: RE: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
Next: Re: areadetector on windows, xml2 done, now Lightfield William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Does anyone have good connections to Agilent? Epics for gas chromatographs/mass spectrometers Ulrik Pedersen via Tech-talk
Next: Re: epics synapps asyn compile error Mark Rivers via Tech-talk
