1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: areadetector on windows, xml2 done, now Lightfield
To: William Kirstaedter <[email protected]>, Freddie Akeroyd - STFC UKRI <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 13 Apr 2023 12:07:09 +0000
Hi William and Freddie,
I suspect the problem may be because of the 3 DLLs that are supplied with ADLightField in ADLightField/lightFieldApp/src.
We are currently running with LightField 6.4.1, we have not updated since 2017.  Those DLLs have this commit message:
corvette:ADLightField/lightFieldApp/src>git log *.dll
commit a73344c230df9478b9186c9f9b1e15354eed5e06
Author: Mark Rivers <[email protected]>
Date:   Thu Nov 30 11:52:41 2017 -0600
    New versions of DLL from Lightfield 6.4.1
The reason those DLLs are provided with ADLightField is explained in ADLightField/iocs/lightFieldIOC/lightFieldApp/src/Makefile which contains this:
PROD_NAME = LightFieldApp
ifeq (windows-x64, $(findstring windows-x64, $(T_A)))
  ifeq ($(STATIC_BUILD), NO)
    PROD_IOC += $(PROD_NAME)
    # Note: Normally it is sufficient to have DLLs in the PATH environment.
    # However, LightField won't start unless the DLLs are in the same directory as this application
    # The DLLs need to be in the ADLightField/lightFieldApp/src directory or the library won't build
    # so we install them into the bin directory from there.
    BIN_INSTALLS += $(ADLIGHTFIELD)/lightFieldApp/src/PrincetonInstruments.LightField.AutomationV4.dll
    BIN_INSTALLS += $(ADLIGHTFIELD)/lightFieldApp/src/PrincetonInstruments.LightFieldAddInSupportServices.dll
    BIN_INSTALLS += $(ADLIGHTFIELD)/lightFieldApp/src/PrincetonInstruments.LightFieldViewV4.dll
  endif
endif
I suggest you make a fresh install of ADLightField and then replace those 3 DLLs with the versions from your much more recent LightField installation.
Sent: Thursday, April 13, 2023 3:44 AM
To: Mark Rivers; Freddie Akeroyd - STFC UKRI; [email protected]
Hey,
unfortunately still no progress :(
dependencywalker reports the same as your dumpbin command.
I set the LIGHTFIELD ROOT into PATH as Freddie suggested, but still no success.
I copied the ARC dll and the FTXX.dll into my IOCs bin folder next to the LightfieldApp.exe.
Still no success, error message still the same.
I also tried upgrading the Automation dll etc from V4 to V5 and rebuild the IOC - same Behaviour. :(
I have no idea what to try next, honestly.
I can try to ask Princeton but I dont expect much, tbh.
Also I could try with the newest version of Lightfield, 6.16 instead of my currently installed 6.14.
But thats it so far I think...
William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG
Faradayweg 4-6 14195 Berlin
Tel: 030 8413 5405 Mail: [email protected]
Am 13.04.2023 um 00:29 schrieb Mark Rivers:
Hi Freddie and William,
I just ran “dumpbin /imports” on ARC_Instrument_x64.dll on our system.  I have appended the output.  It uses the following DLLs:
KERNEL32.dll
USER32.dll
ADVAPI32.dll
SETUPAPI.dll
FTD2XX.dll
MSVCR100.dll
MSVCP100.dll
I think all of these are standard Windows DLLs except FTD2XX.dll.  That comes with LightField, but it probably also comes with other packages, since it is a third party FTDI library.  I suspect the problem is that it is finding an incompatible version of that library.
W:\Program Files\Princeton Instruments\LightField>dumpbin /imports ARC_Instrument_x64.dll
Microsoft (R) COFF/PE Dumper Version 14.00.24215.1
Copyright (C) Microsoft Corporation.  All rights reserved.
Dump of file ARC_Instrument_x64.dll
File Type: DLL
  Section contains the following imports:
    KERNEL32.dll
             18009F060 Import Address Table
             1800C0FC0 Import Name Table
                     0 time date stamp
                     0 Index of first forwarder reference
                         433 SetCommState
                         18B GetCommTimeouts
                         434 SetCommTimeouts
                         4C0 Sleep
                         534 WriteFile
                          42 CancelIo
                         29A GetTickCount
                          F2 EnterCriticalSection
                         33B LeaveCriticalSection
                         2EA InitializeCriticalSection
                          9E CreateMutexW
                         3FD ReleaseMutex
                         27E GetSystemTime
                         346 LocalAlloc
                         34A LocalFree
                          D2 DeleteCriticalSection
                          B4 CreateThread
                         412 ResetEvent
                         168 FreeLibrary
                         18A GetCommState
                         24C GetProcAddress
                          CB DecodePointer
                         4CE TerminateProcess
                          EE EncodePointer
                         4BC SetupComm
                          85 CreateEventW
                         3C3 ReadFile
                         251 GetProcessHeap
                         2DC HeapSize
                         508 WaitForSingleObject
                          8F CreateFileW
                          52 CloseHandle
                         2DA HeapReAlloc
                         2D7 HeapFree
                         2D3 HeapAlloc
                         2D6 HeapDestroy
                         2EB InitializeCriticalSectionAndSpinCount
                         3B4 RaiseException
                         280 GetSystemTimeAsFileTime
                         1C7 GetCurrentProcessId
                         1CB GetCurrentThreadId
                         3A9 QueryPerformanceCounter
                         418 RtlCaptureContext
                         41F RtlLookupFunctionEntry
                         426 RtlVirtualUnwind
                         302 IsDebuggerPresent
                         4B3 SetUnhandledExceptionFilter
                         4E2 UnhandledExceptionFilter
                         1C6 GetCurrentProcess
                         208 GetLastError
                         153 FindResourceExW
                         154 FindResourceW
                         4BF SizeofResource
                         356 LockResource
                         343 LoadResource
                         33E LoadLibraryA
                         369 MultiByteToWideChar
    USER32.dll
             18009F4D8 Import Address Table
             1800C1438 Import Name Table
                     0 time date stamp
                          AF DispatchMessageW
                         220 MsgWaitForMultipleObjects
                         2E7 ShowWindow
                          6E CreateWindowExW
                         251 RegisterClassExW
                          9C DefWindowProcW
                         256 RegisterDeviceNotificationW
                         304 TranslateMessage
                         237 PeekMessageW
    ADVAPI32.dll
             18009F000 Import Address Table
             1800C0F60 Import Name Table
                     0 time date stamp
                         230 RegCloseKey
                         26E RegQueryValueExW
    SETUPAPI.dll
             18009F480 Import Address Table
             1800C13E0 Import Name Table
                     0 time date stamp
                         143 SetupDiEnumDeviceInterfaces
                         16B SetupDiGetDeviceInstanceIdW
                         142 SetupDiEnumDeviceInfo
                         193 SetupDiOpenDevRegKey
                         13F SetupDiDestroyDeviceInfoList
                          57 CM_Get_Device_IDW
                          62 CM_Get_Device_ID_Size
                          82 CM_Get_Parent
                         16E SetupDiGetDeviceInterfaceDetailW
                         156 SetupDiGetClassDevsW
    FTD2XX.dll
             18009F018 Import Address Table
             1800C0F78 Import Name Table
                     0 time date stamp
                             Ordinal     2
                             Ordinal     4
                             Ordinal    31
                             Ordinal    27
                             Ordinal    28
                             Ordinal    40
                             Ordinal    39
                             Ordinal    32
    MSVCR100.dll
             18009F2B0 Import Address Table
             1800C1210 Import Name Table
                     0 time date stamp
                          EE ?_type_info_dtor_internal_method@type_info@@QEAAXXZ
                         146 __crt_debugger_hook
                         5A8 memcmp
                         10E _CxxThrowException
                         11F __CppXcptFilter
                         19E _amsg_exit
                         1F2 _encoded_null
                         287 _initterm_e
                         286 _initterm
                         307 _malloc_crt
                         39D _onexit
                         2F6 _lock
                         148 __dllonexit
                         45B _unlock
                         11E __C_specific_handler
                         100 ?terminate@@YAXXZ
                         5B3 printf
                         548 exit
                         600 towupper
                         621 wcsrchr
                         5A9 memcpy
                         62C wcstoul
                         539 atol
                         302 _ltoa_s
                         59E malloc
                         563 free
                         57D isdigit
                         5EB strtod
                         612 wcschr
                         10A ?what@exception@std@@UEBAPEBDXZ
                         538 atoi
                         5EA strstr
                         5DB strcpy_s
                          78 ??_U@YAPEAX_K@Z
                          63 ??2@YAPEAX_K@Z
                          24 ??0exception@std@@QEAA@AEBV01@@Z
                         5AB memmove
                          5D ??1exception@std@@UEAA@XZ
                          22 ??0exception@std@@QEAA@AEBQEBD@Z
                         60B vswprintf_s
                         47B _vscwprintf
                         58F iswspace
                         625 wcsstr
                         61F wcsnlen
                         4AC _wcslwr_s
                         5AC memmove_s
                         631 wmemcpy_s
                         5AA memcpy_s
                          65 ??3@YAXPEAX@Z
                         128 __CxxFrameHandler3
                         140 __clean_type_info_names_internal
                         5AD memset
                         530 asin
                         5CA sin
                         543 cos
                         4A6 _wcsicmp
                         53E ceil
    MSVCP100.dll
             18009F230 Import Address Table
             1800C1190 Import Name Table
                     0 time date stamp
                         19E ?_Decref@facet@locale@std@@QEAAPEAV123@XZ
                          9E ??1_Lockit@std@@QEAA@XZ
                          60 ??0_Lockit@std@@QEAA@H@Z
                         251 ?_Orphan_all@_Container_base0@std@@QEAAXXZ
                         36B ?endl@std@@YAAEAV?$basic_ostream@DU?$char_traits@D@std@@@1@AEAV21@@Z
                         59C ?setstate@?$basic_ios@DU?$char_traits@D@std@@@std@@QEAAXH_N@Z
                         10F ??6?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV01@P6AAEAV01@AEAV01@@Z@Z
                         391 ?flush@?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAAEAV12@XZ
                         5C5 ?sputc@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QEAAHD@Z
                         253 ?_Osfx@?$basic_ostream@DU?$char_traits@D@std@@@std@@QEAAXXZ
                         5C8 ?sputn@?$basic_streambuf@DU?$char_traits@D@std@@@std@@QEAA_JPEBD_J@Z
                         28C ?_Xlength_error@std@@YAXPEBD@Z
                         60D ?uncaught_exception@std@@YA_NXZ
                         2A7 ?cout@std@@3V?$basic_ostream@DU?$char_traits@D@std@@@1@A
                         28E ?_Xout_of_range@std@@YAXPEBD@Z
  Summary
       24000 .data
        3000 .pdata
       27000 .rdata
        1000 .reloc
        1000 .rsrc
       9E000 .text
From: Freddie Akeroyd - STFC UKRI <[email protected]>
Sent: Wednesday, April 12, 2023 5:12 PM
To: William Kirstaedter <[email protected]>; Mark Rivers <[email protected]>; [email protected]
Subject: RE: areadetector on windows, xml2 done, now Lightfield
Hi William,
lightfield may load it dynamically at runtime then (like areadetector) and so it will not show up in dependencywalker. Loading ARC_Instrument_x64.dll itself into dependencywalker may be most useful then,  one possible cause of the problem you are seeing is that ARC_Instrument_x64.dll is loading an incompatible dependent library when activated by EPICS and dependencywalker will show the dependent libraries it uses and may give some clues to this.
One difference between running LightfieldApp.exe directly and loading the library via areadetector is that the directory containing the LightfieldApp.exe program will automatically get added as the first place to look for any DLL dependencies of ARC_Instrument_x64.dll. Is the lightfield directory already in PATH? If not, one thing to try first is to edit your start_epics.bat so after running dllPath.bat it then does
    set “PATH=%LIGHTFIELD_ROOT%;%PATH%”
so the directory that contains lightfield.exe is searched first for any DLL dependencies
Freddie
Sent: 12 April 2023 16:23
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; Mark Rivers <[email protected]>; [email protected]
Hey Freddie, I think I might need some guidance on this.
I loaded my IOCs LightfieldApp.exe and also the Princeton.Lightfield.exe (this does not load anything ?!) in dependencywalker, but none of them seems to load the ARC_...dll.
is there a better way than loading and scrolling through the list to search for my ARC.dll?
it wasnt obvious :(
thanks,
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Am 28.03.2023 um 01:02 schrieb Freddie Akeroyd - STFC UKRI:
In other situations I have seen DLL load errors caused by a dependency of the DLL in question not being found i.e. ARC_Instrument_x64.dll may be present in the right place but one of the DLLs it depends on (and is located via the PATH environment variable) might be either not found or an old/incorrect version of this required file was installed by another program which happens to be earlier in PATH and so is picked up instead. Programs like dependency walker   https://www.dependencywalker.com/  can help locate such clashes if that is the problem
Freddie
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: 27 March 2023 23:21
To: William Kirstaedter <[email protected]>; tech-talk <[email protected]>
Hi William,
I am trying to understand why you get that missing DLL error.
Can run the camera OK using LightField as a stand-alone application without EPICS?
Do you have more than one version of LightField installed?
ADLightField does not call that DLL explicitly, it just starts LightField in this line:
https://github.com/areaDetector/ADLightField/blob/3383118260b82d95255f303d673e04d4de0123c9/lightFieldApp/src/LightField.cpp#L410
The missing DLL is ARC_Instrument_x64.dll.  I have attached a screen shot showing the size and location of that file on my system.  What do you see on your system?
RE: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
Prev: areaDetector error in mingw, windows lynn via Tech-talk
Next: Re: epics synapps asyn compile error Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: areadetector on windows, xml2 done, now Lightfield William Kirstaedter via Tech-talk
Next: RE: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
