1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Motor module compile (dbdExpand.pl:can't find file asSupport.dbd)
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Sat, 15 Apr 2023 00:23:15 +0900
I don’t know how to compile this motor module.. (Before I did it fortunately, after I make clean, it doesn’t work now..)
Please help me or give me any solution, it will be really appreciate it.
Motor module directory path: /usr/local/epics/main/modules/synApps/support/motor/modules/motor_old
ls > configure docs iocs motorApp Makefile   (in motor_old, 5 file)
cd > iocs
iocs ls > motorIOC Makefile   (in iocs, 2 file)
-> make
error message after make:
perl -CSD /usr/local/epics/main/base/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/usr/local/epics/main/modules/synApps/support/motor-R7-2-1/dbd
-I/usr/local/epics/main/modules/synApps/support/asyn/dbd -I/usr/local/epics/main/modules/synApps/support/seq/dbd -I/usr/local/epics/main/modules/synApps/support/busy/dbd
-I/usr/local/epics/main/modules/synApps/support/ipac/dbd -I/usr/local/epics/main/base/dbd
-o motor.dbd base.dbd asyn.dbd drvAsynSerialPort.dbd drvAsynIPPort.dbd devAsynOctet.dbd devAsynRecord.dbd motorSupport.dbd motorMotor.dbd asSupport.dbd
dbdExpand.pl: Can't find file 'asSupport.dbd'
  while reading 'asSupport.dbd' to create 'motor.dbd'
  Your Makefile may need this dependency rule:
    $(COMMON_DIR)/motor.dbd: $(COMMON_DIR)/asSupport.dbd
dbdExpand.pl: Exiting due to errors
make[4]: *** No rule to make target '../O.Common/motor.dbd', needed by 'build'.  Stop.
make[4]: Leaving directory '/usr/local/epics/main/modules/synApps/support/motor-R7-2-1/modules/motor_old/iocs/motorIOC/motorApp/src/O.linux-x86_64'
make[3]: *** [/usr/local/epics/main/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[3]: Leaving directory '/usr/local/epics/main/modules/synApps/support/motor-R7-2-1/modules/motor_old/iocs/motorIOC/motorApp/src'
make[2]: *** [/usr/local/epics/main/base/configure/RULES_DIRS:85: src.install] Error 2
make[2]: Leaving directory '/usr/local/epics/main/modules/synApps/support/motor-R7-2-1/modules/motor_old/iocs/motorIOC/motorApp'
make[1]: *** [/usr/local/epics/main/base/configure/RULES_DIRS:85: motorApp.install] Error 2
make[1]: Leaving directory '/usr/local/epics/main/modules/synApps/support/motor-R7-2-1/modules/motor_old/iocs/motorIOC'
make: *** [/usr/local/epics/main/base/configure/RULES_DIRS:85: motorIOC.install] Error 2
How can I fix this error?
Re: Motor module compile (dbdExpand.pl:can't find file asSupport.dbd) Kevin Peterson via Tech-talk
Prev: Re: Is the Sequencer and SNL still widely used? Murray, Doug via Tech-talk
Next: Re: Motor module compile (dbdExpand.pl:can't find file asSupport.dbd) Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Open positions at PSI: Group Leader for Infrastructure and Services, Motion Control Specialist Baymani Simaolhoda via Tech-talk
