1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Question about asynMotor record, limits
From: Borys Lysyansky via Tech-talk <[email protected]>
To: [email protected]
Date: Fri, 21 Apr 2023 12:33:18 +0200
I have the following problem:
I have my asynMotor record with the following lines in
motor.substitutions:
{P,     N,   M,        DTYP,        PORT,             ADDR,  DESC,          EGU,   DIR,  VELO,  VBAS,  ACCL, BDST,  BVEL, BACC,  MRES,  PREC,   DHLM, DLLM, INIT}
{PREFIX:,  1,  "WL",         "asynMotor",  MyController,  0,  "motor $(N)",  nm,    Pos,  .0,   .0,    .0,    0,     1,    .2,    1e-6,     6,       17,     2,  "0"}
During the program run I would like to change the motor limits, which are now 2..17 with
the following code:
auto status1 = m_pAxes[0]->setDoubleParam(motorLowLimit_, newLowValue * 1e6);
auto status2 = m_pAxes[0]->setDoubleParam(motorHighLimit_, newHighValue * 1e6);
Both obtained status are asynSuccess. I have also checked the result by
calling
double lowLimit = 0, highLimit= 0;
getDoubleParam (0, motorLowLimit_,     &lowLimit);
getDoubleParam (0, motorHighLimit_, &highLimit);
It was also correct. However, I would expect that the new low/high limits
should have impact on commands
caput PREFIX:WL.VAL someValue
However, the program behavior here is somehow strange.
Could you, please, explain me it.
With best wishes,
Boris
Re: Question about asynMotor record, limits Mark Rivers via Tech-talk
Prev: Re: About "Identical process variable names on multiple servers" with invalid address Perez Juarez, Emilio (DLSLtd, RAL, LSCI) via Tech-talk
Next: RE: Search all PV available CAOUEN Loic via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: [EXTERNAL] Re: opc ua client Sinclair, John via Tech-talk
Next: Re: Question about asynMotor record, limits Mark Rivers via Tech-talk
