1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: mbbo with 32 choices
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: "Le, An" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 21 Apr 2023 21:12:58 +0000
You don’t mention anything about the application and so I’m not sure if this useful, but I’ve pasted below a database snippet that lets you choose N options by writing to a longout. This particular example is for 19 options, but it can be extended to 32 by adding an two additional calcout and sseq. Or, the sseq could be replaced by many calcout. Although for very high N it would tedious unless you autogenerated the database.
On the client side, it’s easiest just to have a text entry and let the user type the number they want, and that’s the most portable solution. But if you are using CS-Studio you can manually specify N options for a drop down menu using a Combo Box. And if you specify the options as simple integers you can write directly to the longout record. If you really wanted characters in the drop down menu there might be some way to use scalcout to extract the integer from the menu text as long as the integer is part of the text.
Cheers,
Matt
record(longout, "$(S):Menu") {
  field(DRVL, "0")
  field(DRVH, "18")
  field(FLNK, "$(S):MenuSel")
  info(autosaveFields_pass0, "VAL")
record(calcout, "$(S):MenuSel") {
  field(INPA, "$(S):Menu NPP MS")
  field(CALC, "(A>=0)&&(A<=9)?A+1:0")
  field(DOPT, "Use CALC")
  field(OOPT, "When Non-zero")
  field(OUT, "$(S):PosGoList.SELN PP")
  field(FLNK, "$(S):MenuSel2")
record(calcout, "$(S):MenuSel2") {
  field(CALC, "(A>=10)&&(A<=18)?(A-9):0")
  field(OUT, "$(S):PosGoList2.SELN PP")
record(sseq, "$(S):PosGoList") {
  field(SELM, "Specified")
  field(WAIT1, "Wait")
  field(WAIT2, "Wait")
  field(WAIT3, "Wait")
  field(WAIT4, "Wait")
  field(WAIT5, "Wait")
  field(WAIT6, "Wait")
  field(WAIT7, "Wait")
  field(WAIT8, "Wait")
  field(WAIT9, "Wait")
  field(WAITA, "Wait")
  field(DOL1, "1")
  field(DOL2, "1")
  field(DOL3, "1")
  field(DOL4, "1")
  field(DOL5, "1")
  field(DOL6, "1")
  field(DOL7, "1")
  field(DOL8, "1")
  field(DOL9, "1")
  field(DOLA, "1")
  field(LNK1, "$(S):Pos0Go.PROC CA")
  field(LNK2, "$(S):Pos1Go.PROC CA")
  field(LNK3, "$(S):Pos2Go.PROC CA")
  field(LNK4, "$(S):Pos3Go.PROC CA")
  field(LNK5, "$(S):Pos4Go.PROC CA")
  field(LNK6, "$(S):Pos5Go.PROC CA")
  field(LNK7, "$(S):Pos6Go.PROC CA")
  field(LNK8, "$(S):Pos7Go.PROC CA")
  field(LNK9, "$(S):Pos8Go.PROC CA")
  field(LNKA, "$(S):Pos9Go.PROC CA")
record(sseq, "$(S):PosGoList2") {
  field(DOL1, "1")
  field(DOL2, "1")
  field(DOL3, "1")
  field(DOL4, "1")
  field(DOL5, "1")
  field(DOL6, "1")
  field(DOL7, "1")
  field(DOL8, "1")
  field(DOL9, "1")
  field(LNK1, "$(S):Pos10Go.PROC CA")
  field(LNK2, "$(S):Pos11Go.PROC CA")
  field(LNK3, "$(S):Pos12Go.PROC CA")
  field(LNK4, "$(S):Pos13Go.PROC CA")
  field(LNK5, "$(S):Pos14Go.PROC CA")
  field(LNK6, "$(S):Pos15Go.PROC CA")
  field(LNK7, "$(S):Pos16Go.PROC CA")
  field(LNK8, "$(S):Pos17Go.PROC CA")
  field(LNK9, "$(S):Pos18Go.PROC CA")
From: Tech-talk <[email protected]> On Behalf Of Le, An via Tech-talk
Sent: Friday, April 21, 2023 1:41 PM
To: [email protected]
Subject: [EXTERNAL] mbbo with 32 choices
Hello,
I’m looking for an mbbo-like record type that supports 32 choices instead of 16. Has anyone already written an implementation for this?
An Le
SLAC National Accelerator Laboratory
Re: mbbo with 32 choices Maren Purves via Tech-talk
mbbo with 32 choices Le, An via Tech-talk
Prev: PV access stopped by the firewall CentOS 9 Stream Leblanc, Gregory via Tech-talk
Next: Re: mbbo with 32 choices Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: mbbo with 32 choices Kasemir, Kay via Tech-talk
Next: Re: mbbo with 32 choices Maren Purves via Tech-talk
