1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: question about ALIAS
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Sun, 23 Apr 2023 18:33:31 -0500
Hi Jiaosai Li,
On Sun, 23 Apr 2023 at 12:54, 李姣赛 via Tech-talk <[email protected]> wrote:
 I am trying to set up a gateway(V2_1_3 with base3.15.9), and I find the pvlist file is not working. I can't find the PVs' ALIAS name.
The gateway command is:
./gateway -sip 192.168.2.170 -cip "192.168.2.171:5064 192.168.2.172:5064 192.168.2.173:5064" -pvlt ./GATEWAY.pvlist -access ./GATEWAY.access -debug 1 -log gateway.log
My pvlist is "GATEWAY.pvlist". It contains:
EVALUATION ORDER   ALLOW,DENY
[0-9].*        ALLOW
[a-z].*        ALLOW
[A-Z].*        ALLOW
^test            ALIAS gateway:test
Beam:.*        DENY
PS.*            ALLOW PowerSupply 1
ps\([0-9]\)        ALIAS PSCurrent\1.ai PowerSupply 1
# Convert old Gateway internal process variable names
gateway\.\(.*\)            ALIAS     gateway:\1
gateway\.\(.*\)Flag        ALIAS     gateway:\1Flag          GatewayAdmin
gateway\.alive             ALIAS     gateway:connected
gateway\.postEventRate     ALIAS     gateway:clientPostRate
__________________________________________________________________________________________
I can access the PV test:OprRun
[TimeLjs@node1 Heartbeat-3-0-958e11be8686]$ caget test:OprRun
test:OprRun                    0
but I can't access the PV test_gw:OprRun
[TimeLjs@node1 Heartbeat-3-0-958e11be8686]$ caget gateway:test:OprRun
Channel connect timed out: 'gateway:test:OprRun' not found.
I think the command "^test        ALIAS gateway:test" doesn't work.(I have installed Perl-5.36.0)
Does anyone have any idea what's going on? Any suggestion?
Your configuration does not contain an ALIAS command with a regular _expression_ that matches the name of your internal PV.
Please check how the lines near the bottom of your configuration use the parentheses and replacement operators to create an alias conversion for multiple names.
To add the prefix "gateway:" to anything that starts with "test", you could use something like:
\(test.*\)    ALIAS    gateway:\1
\1 is replaced with whatever is inside the first pair of parentheses in a matched regex. A name "test:OprRun" matches and will be aliased to "gateway:test:OprRun"
Cheers,
~Ralph
Re: question about ALIAS Ralph Lange via Tech-talk
question about ALIAS 李姣赛 via Tech-talk
Prev: question about ALIAS 李姣赛 via Tech-talk
Next: Re: question about ALIAS Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
