1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: PV access stopped by the firewall CentOS 9 Stream
To: "Leblanc, Gregory" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 24 Apr 2023 06:44:32 +0000
Hi Greg,
The PVAccess uses ports 5075 and 5076 for its operation (you can also see that in your output of the ss command).
If you add the ports 5075 and 5076 to your firewall rules, I think it should work.
Best regards,
Žiga
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Leblanc,
> Gregory via Tech-talk
> Sent: Friday, April 21, 2023 10:09 PM
> To: [email protected]
> Subject: PV access stopped by the firewall CentOS 9 Stream
> Caution: This email originated from outside of Cosylab.
> Hi folks,
> I've just installed CentOS 9 stream on a new machine here, then added on
> epics-base, calc, asyn, and StreamDevice from git.  I've also installed my work
> in progress for the Keysight 34980A mainframes, which speak SCPI.  All the
> EPICS bits work, but there's something screwy with the firewall.  When I do " $
> pvget KS_34980A_EPICStestswitcherMagnetCurrent" it times out in 5
> seconds.  "$ caget KS_34980A_EPICStestswitcherMagnetCurrent" works just
> fine.  I can turn the firewall off ($ sudo systemctl stop firewalld) and then
> pvget works fine.  I added ports 5064 and 5065 in both TCP and UDP to the
> rules for the firewall, but that didn't seem to help.
> Firewall rules:
> $ sudo firewallcmd --list-all
> [sudo] password for leblanc:
> sudo: firewallcmd: command not found
> [leblanc@epics1 ~]$ sudo firewall-cmd --list-all public (active)
>   target: default
>   icmp-block-inversion: no
>   interfaces: enp1s0
>   sources:
>   services: cockpit dhcpv6-client ssh
>   ports: 5064/tcp 5065/tcp 5064/udp 5065/udp
>   protocols:
>   forward: yes
>   masquerade: no
>   forward-ports:
>   source-ports:
>   icmp-blocks:
>   rich rules:
> I also used ss to see what ports pvget was trying to use
> $ ss -antup |grep pvget
> udp   UNCONN 0      0                0.0.0.0:45383      0.0.0.0:*
> users:(("pvget",pid=49094,fd=3))
> udp   UNCONN 0      0            224.0.0.128:5076       0.0.0.0:*
> users:(("pvget",pid=49094,fd=6))
> udp   UNCONN 0      0           10.0.255.255:5076       0.0.0.0:*
> users:(("pvget",pid=49094,fd=5))
> udp   UNCONN 0      0             10.0.0.239:5076       0.0.0.0:*
> users:(("pvget",pid=49094,fd=4))
> I'm not sure what else to try at this point.  Any pointers appreciated.
>     Greg
> Gregory Leblanc
> Accelerator Engineer
> Edwards Accelerator Lab - Ohio University
> 123 University Terrace
> Athens, OH 45701 USA
> [email protected]
> M: (401) 52-OUAL1 or (401) 526-8251
RE: [External] RE: PV access stopped by the firewall CentOS 9 Stream Leblanc, Gregory via Tech-talk
Prev: Re: question about ALIAS Ralph Lange via Tech-talk
Next: RE: opc ua client Konrad Gajewski via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: PV access stopped by the firewall CentOS 9 Stream Leblanc, Gregory via Tech-talk
Next: RE: [External] RE: PV access stopped by the firewall CentOS 9 Stream Leblanc, Gregory via Tech-talk
