Hi!
I tried to build base-3.15.9 on a system which accidentally lacked g++
compiler and encountered a weird behaviour: instead of stopping the build
process upon first error, "make" continued and stopped much later due to
inability to make a target:
Installing generic include file ../../../include/yajl_gen.h
Installing generic include file ../../../include/yajl_parse.h
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/ti
mer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -c ../../../src/libCom/osi/os/posix/epicsTempFile.cpp
make[3]: /usr/bin/g++: No such file or directory
/usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -
I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF warshall.d ../../../src/libCom/yacc/warshall.c
mer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF resourceLib.d ../../../src/libCom/cxxTemplates/resourceLib.cpp
Installing html ../../../html/./freeList/freeList.html
mkdir ../../../html/./freeList
Installing html ../../../html/./gpHash/gpHash.html
mkdir ../../../html/./gpHash
make[3]: *** No rule to make target 'epicsTempFile.o', needed by 'antelope'. Stop.
make[3]: Leaving directory '/tmp/x/base-3.15.9/src/libCom/O.linux-x86_64'
make[2]: *** [../../configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/tmp/x/base-3.15.9/src/libCom'
make[1]: *** [../configure/RULES_DIRS:85: libCom.install] Error 2
make[1]: Leaving directory '/tmp/x/base-3.15.9/src'
This can be easily reproduced via e.g. "make CCC=/NON/EXISTENT":
/NON/EXISTENT -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libC
om/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -c ../../../src/libCom/osi/os/posix/epicsTempFile.cpp
make[3]: /NON/EXISTENT: Command not found
er -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF warshall.d ../../../src/libCom/yacc/warshall.c
om/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -MM -MF resourceLib.d ../../../src/libCom/cxxTemplates/resourceLib.cpp
make[3]: *** No rule to make target `epicsTempFile.o', needed by `antelope'. Stop.
make[3]: Leaving directory `/tmp/x/base-3.15.9/src/libCom/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/tmp/x/base-3.15.9/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/tmp/x/base-3.15.9/src'
make: *** [src.install] Error 2
Why does this happen? Grepping through the whole base-3.15.9/ dir doesn't
show a reason: neither ".IGNORE:" special target nor "-i" or "--ignore"
flags.
Is this the intended behaviour? Shouldn't "make" stop on first error?
P.S. This is CentOS-7.3 on x86_64, but that's irrelevant, as the same
happens on other distros and architectures.
- Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Johnson, Andrew N. via Tech-talk
Re: [EXTERNAL] Re: opc ua client Sinclair, John via Tech-talk
Could not use autosave with motorOmsAsyn whitetiger1123 via Tech-talk
<2023>
2025
Re: question about ALIAS 李姣赛 via Tech-talk
<2023>
2025
